BT.com
Wishlist
Sandisk CloudSpeed Ascend 240GB SSD 2.5" SATA 6Gb/s
Delivery
Standard Due date unavailable
SanDisk's CloudSpeed Ascend SSDs target read-intensive application workloads, such as file servers, Web-based applications, and virtual tape libraries (VTL). Along with SanDisk's Guardian Technology platform and the latest generation of consumer multi-level cell (MLC) NAND flash technology, they deliver all the features expected from an enterprise-class SSD - at a great value.
SanDisk CloudSpeed Ascend - solid state drive - 240 GB - SATA 6Gb/s
Solid state drive - internal
240 GB
NAND Flash Memory Type
19nm multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Power Failure Recovery, Error Correction Code (ECC), FlashGuard Technology, DataGuard Technology, EverGuard Technology, Guardian Technology Platform, Data Path Protection, S.M.A.R.T.
69.85 mm x 100.2 mm x 7 mm
5 years warranty
240 GB
2.5"
SATA 6Gb/s
69.85 mm
100.2 mm
7 mm
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
450 MBps (read) / 400 MBps (write)
4KB Random Read
80000 IOPS
4KB Random Write
15000 IOPS
Reliability
MTBF
2,500,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
5.2 Watt (active) , 2.2 Watt (idle)
Limited warranty - 5 years
70 °C
5 - 95% (non-condensing)
Vibration Tolerance
2.17 g @ 7-800 Hz (operating)
Scroll to top
