BT.com
Wishlist
Sandisk 64GB Ultra Dual USB 3.0 Flash Drive
Delivery
Standard Due date unavailable
Quickly and easily transfer your files between OTG-enabled Android smartphones and tablets and PC and Mac computers.  Simply connect the SanDisk Ultra Dual USB Drive 3.0 to the micro-USB port of your Android device and move up to 64GB of content to the drive, freeing up space to add photos, videos, songs, and more. The high-speed USB 3.0 connector enables you to transfer files rapidly, at up to 130MB/s, from drive to computer. Spend less time waiting to transfer a full-length movie to the drive than with a standard USB 2.0 drive .The SanDisk Memory Zone app (available on Google Play ) helps you manage your phone's or tablet's memory , making it easy to move, view, copy, or backup your photos and videos to the drive, so you're always ready to take more videos and pictures on the go.
SanDisk Ultra Dual - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Latin America, Asia Pacific, Middle East, Africa, Europe
Software Included
SanDisk Memory Zone
Apple MacOS X 10.6 or later, Android, Microsoft Windows Vista / 7 / 8
Microsoft Certification
Compatible with Windows 7
5 years warranty
USB flash drive
Storage Capacity
64 GB
Compatibility
Non-specific
Read Rate
Up to 130 MB/s
Interface Type
USB 3.0
USB On-The-Go compatible, USB and micro-USB Dual connector
Plug and Play
Software Included
SanDisk Memory Zone
Limited warranty - 5 years
11 mm
19.8 mm
36.6 mm
45 °C
Scroll to top
