BT.com
Wishlist
Sandisk 480GB Ultra II SATA 6GB/s 2.5" Solid State Drive
Delivery
Standard Due date unavailable
Boost your PC's performance by up to 28x with an easy and affordable upgrade to SanDisk Ultra II SSD. You'll enjoy no-wait boot up, and shorter application load and data transfer times than your traditional hard drive ever delivered – plus longer battery life and much cooler, quieter computing, too1. No matter how you use your PC, SanDisk's nCache 2.0 technology makes for a better experience, delivering high speed and staying power, even when you're socialising, shopping and watching the football, all at once. Proven shock and vibration resistance means you won't lose your data even if you drop your computer. When you're ready for a better computing experience without buying a new computer, this easy-to-do-yourself upgrade to SanDisk Ultra II SSD will make your old PC behave like a brand-new machine.
SanDisk Ultra II - solid state drive - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
69.85 mm x 100.5 mm x 7 mm
North America
Microsoft Certification
Compatible with Windows 7
3 years warranty
480 GB
2.5"
SATA 6Gb/s
69.85 mm
100.5 mm
7 mm
Performance
Drive Transfer Rate
600 MBps (external)
Reliability
MTBF
1,750,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
North America
Limited warranty - 3 years
70 °C
Shock Tolerance (operating)
1500 g
Vibration Tolerance (operating)
5 g @ 10-2000 Hz
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Fast looking lump of plastic
Reviewed by Mustang on 26/10/2015
This is my first SSD after my 500GB WD Green drive died.
I wasn't expecting much to be fair, especially when it arrived. To be fair I'm not sure what I was expecting, but it's just a small very lightweight plastic box. Hard to believe what it can do!!!
Boot up from cold to usable gone from at least 3 mins, to under 30 seconds.
IE11 loads in less than a second, and the Secondlife viewer Firestorm from 1st click to being logged on in about 10 seconds.
So far so good, early days yet, but for now can not fault this drive.
5* Sandisk Super boot up time
Reviewed by Jonas on 27/09/2015
Sandisk 480GB Ultra II SATA 6GB super boot up time
Scroll to top
