BT.com
Wishlist
Sandisk 480GB Extreme PRO SATA 6GB/s 2.5" Solid State Drive
Sandisk 480GB Extreme PRO SATA...
£243.78
Play Games? Make Games? It's Time To Get Extreme!
Hurry, only 2 left in stock!
£243.78
Add to wishlist
Delivery
Standard 1-3 working days
Whether it's extending the life for your PC or improving your gameplay, the SanDisk Extreme SSD is the reliable drive for you. Enjoy lightning fast performance, providing next-level speed for your graphic-intense games. Get faster load times enhancing your gaming experience from boot-up to shut-down and every in-game moment in-between.
Play games? Make games? It's time to get Extreme
Game without limits when you step up to the 24/7 high-performance nCache™ Pro Technology delivers. Graphics-intensive games load in a heartbeat and run blazing fast to keep you immersed in the action.
  • Innovative nCache™ Pro technology delivers consistent high performance
  • Pro-level read and write speeds
  • Load and run games and graphics-intensive applications blazing fast
  • Industry-leading 10 year limited warranty**
  • Easy-to-use SSD Dashboard for drive monitoring and management
  • Cool, quiet operation and low power consumption
Why SanDisk Extreme PRO SSD? It's simple. No stall. No stutter. No crash and burn. Just speed.
Extreme Performance
  • Consistent performance you can count on
  • Low latency
Extreme Reliability
  • Engineered to optimize drive endurance
  • Huge storage capacities
  • SSD Dashboard reports drive status
Environmental Soundness
  • Cool, quiet, energy-efficient operation, with no moving parts
  • Lower power consumption
  • Up to 33% longer laptop life
What does sustainable high performance mean?
The performance numbers SanDisk makes public reflect the speed SanDisk Extreme PRO® SSD maintains over time with sustained heavy use, not the peak it achieved for only a few seconds. This translates into years of lightning fast gaming and multimedia.
Tech Stuff
Because you like to know what's under the hood, here's how we make SanDisk Extreme PRO SSD deliver an exceptional gaming experience.
  • Innovative nCache™ Pro technology delivers sustainable high performance 24 x 7 x 365
  • Over-provisioning and over-clocking offer faster performance and long term endurance
  • SanDisk's proprietary tiered caching across three storage layers optimizes write performance and responsiveness
  • SanDisk SATA SSDs are built with the highest quality NAND memory
  • TRIM support and Background Garbage Collection constantly free up unallocated blocks that once held data to lower latency and boost performance
  • Thermal throttling protects critical drive components against extreme high temperatures to ensure data integrity
  • SanDisk SSD Dashboard includes S.M.A.R.T. support to monitor the health of your SSD in real time to prevent data loss
  • Available capacities: 240GB, 480GB and 960GB**
  • Dimensions: 2.75 x 3.96 x 0.28 in. (69.85mm x 100.5mm x 7.0 mm)
  • Operating temperature: 32ºF to 158ºF (0ºC to 70 ºC)
  • Storage temperature: -67ºF to 185ºF (-55ºC to 85ºC)
  • Interface: SATA Revision 3.0 (6 Gb/s)
  • Shock: Resistant up to 1500 G @ 0.5 m/sec
  • Vibration (Operating/Non-operating) : 5 gRMS, 10-2000 HZ / 4.9 gRMS, 7-800 HZ
  • Power Consumption (active): 0.13w (240 GB), 0.15w (480 GB, 960 GB)
  • Support: 10 year limited warranty**
Performance
  • Seq. Read (up to): 550 MB/s
  • Seq. Write (up to): 515 MB/s
  • Rnd. Read (up to): 100K IOPS
  • Rnd. Write (up to): 90K IOPS
SanDisk Extreme PRO - solid state drive - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant, Background Garbage Collection, TRIM support, Thermal throttling, Tiered Caching Technology, nCache Pro technology, S.M.A.R.T.
69.85 mm x 100.5 mm x 7 mm
Latin America, Asia Pacific, Middle East, Africa, United States
Microsoft Certification
Compatible with Windows 7
10 years warranty
480 GB
2.5"
SATA 6Gb/s
69.85 mm
100.5 mm
7 mm
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 515 MBps (write)
4KB Random Read
100000 IOPS
4KB Random Write
90000 IOPS
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
0.15 Watt (active)
Limited warranty - 10 years
70 °C
Shock Tolerance
1500 g @ 0.5ms
Vibration Tolerance
5 g @ 10-2000 Hz (operating) / 4.9 g @ 7-800 Hz (non-operating)
Other bundles
Sandisk 480GB Extreme PRO SATA 6GB/s 2.5" Solid State...
£243.78
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.60
£247.38
Resources
The following resources are available for the Sandisk 480GB Extreme PRO SATA 6GB/s 2.5" Solid State Drive
Scroll to top
