BT.com
Wishlist
Sandisk 32GB Ultra Fit USB 3.0 Flash Drive
Delivery
Standard Due date unavailable
The ultra-small, low-profile 32GB SanDisk Ultra Fit High-Speed USB 3.0 Flash Drive offers incredible high-speeds in a tiny package. Its clever design means you can plug it neatly into notebooks, tablets, TVs or car audios, even in the tightest spaces. Then you can just leave it there for easy access to extra storage, without fear of knocking or breaking it. If you would rather move media extra-fast between devices, its USB 3.0 speeds mean that now you can enjoy write speeds up to 10x faster than standard USB 2.0 drives and transfer a full-length movie in 40 seconds1. It also gives you a big 32GB of storage space, ready to hold massive files. The included SanDisk SecureAccess software provides password protection and 128-bit encryption2 for your private files, giving you extra reassurance that your files will be safe when you're taking them out and about.
SanDisk Ultra Fit - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
Encryption Algorithm
128-bit AES
Latin America, Asia Pacific, Middle East, Africa, Europe
Software Included
RescuePRO (1 year download), SanDisk SecureAccess 3.0
Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Windows 8
Microsoft Certification
Compatible with Windows 7
5 years warranty
USB flash drive
Storage Capacity
32 GB
128-bit AES
Compatibility
Non-specific
Read Rate
Up to 130 MB/s
Interface Type
USB 3.0
AES-128
Software Included
Limited warranty - 5 years
15.9 mm
19.1 mm
8.8 mm
45 °C
Scroll to top
