BT.com
Wishlist
Sandisk 240GB Extreme SATA 6Gb/s 2.5" Solid State Drive
Delivery
Standard Due date unavailable
Keep time on your side, by upgrading your notebook with the high-performance, SanDisk Extreme Solid State Drive. This reliable SSD boots-up your system up to twice as fast and launches applications 16 times faster than a 7200 rpm hard drive. SanDisk Ultra SSD endures shocks and vibration.
Upgrade your laptop for better performance and extend its reliability by replacing your hard disk drive§ with the SanDisk Extreme® SSD. You'll enjoy faster boot-ups and open files compared to a 7200 RPM hard drive. The SanDisk Extreme SSD is backed by rigorous shock and vibration testing and a 3-year limited warranty†. The SanDisk SSD features no moving parts, quiet operation, and low power consumption as compared to a 7200 RPM hard drive.
Specifications/Features
  • Delivers reliability, durability, and performance for your laptop
  • Open/close/boot up files fast--the rugged SanDisk Extreme SSD can open, close or boot up files faster as compared to a 7200 RPM HDD§
  • Lightning read and write performance-- lighting fast performance
  • Designed for high durability--engineered to withstand shocks and vibration
  • Save on IT maintenance costs--you can defer laptop purchase costs and reduce maintenance requests associated with disk drive failure by replacing standard hard drives with SanDisk Extreme SSD's
  • Lower power consumption--as compared to a standard 7200 RPM Hard Disk Drive
  • Noise reduction--No generation of noise during drive operation
  • Available Capacities - 120 GB*, 240 GB*, 480 GB*
Additional Specifications
  • Interface: SATA 6 Gb/s (backward compatible to SATA 3 Gb/s & SATA 1.5 Gb/s)
  • Temperature (operating/Non-operating) : 0°C to 70°C / -55°C to 95C
  • Power Active: 0.6W
  • Shock Resistant: 1500G @ 0.5 msec
  • Vibration (operating/Non-operating): 2.17gRMS, 5- 700Hz / 3.13gRMS, 5-800Hz
Performance 240GB
  • Sequential Read (up to) 550 MB/s
  • Sequential Write (up to) 520 MB/s
  • Random Read ( up to) 33K IOPS
  • Random Write (up to) 83K IOPS
  • MTBF 2.0M hrs
§ Based on SanDisk internal testing using Microsoft Windows Performance Tool Kit. Performance varies depending upon host device, OS and application. Platform: Dell Optiplex 990, Intel® Core™ i7-2600 CPU @ 3.4GHz, 2GB RAM; OS: Microsoft Windows 7 Ultimate
See Sandisk Extreme SSDs In Action
SanDisk Extreme - solid state drive - 240 GB - SATA 6Gb/s
Solid state drive - internal
240 GB
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant
70 mm x 101 mm x 9.5 mm
78 g
3 years warranty
240 GB
2.5" x 1/8H
SATA 6Gb/s
Shock resistant
70 mm
101 mm
9.5 mm
78 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 460 MBps (write)
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
Limited warranty - 3 years
70 °C
Shock Tolerance
1500 g @ 0.5ms
Vibration Tolerance
2.17 g @ 5-700 Hz (operating)
Scroll to top
