BT.com
Wishlist
Sandisk 16GB Extreme Pro SDHC 280MB/s
Delivery
Standard Due date unavailable
The SanDisk Extreme PRO SDXC UHS-II 16GB card brings you the high performance that today's professional photographers and videographers need to take outstanding shots with high-speed burst mode and capture cinema-quality 4K and Full HD videos . With faster transfer speeds, it also helps you improve post-production workflow efficiency to give you better all-round results. The world's fastest SDXC card, the 16GB SanDisk Extreme PRO SDXC UHS-II card delivers up to 250MB/s write speed. With that speed, you can take remarkable continuous burst-mode shots with your DSLR to make sure that you capture the one you want. Once you've taken your photos, extreme transfer speeds of up to 280MB/s ensure that your workflow becomes even more efficient. The SanDisk Extreme PRO SDXC UHS-II 16GB card also helps you capture high-quality video: it meets the new U3 video capture specification with a minimum sustained video capture rate of 30MB/s for cinema quality 4K, 3D and Full HD video recording . Best results come when used in conjunction with the SanDisk Extreme PRO SD UHS-II Card Reader/Writer (available separately).
SanDisk Extreme Pro - flash memory card - 16 GB - SDHC UHS-II
Flash memory card
SDHC UHS-II Memory Card
Storage Capacity
16 GB
Speed Rating
UHS Class 3 - 1667x/1867x
Software Included
RescuePRO Deluxe (1 year download)
Flash memory card
Storage Capacity
16 GB
Compatibility
Non-specific
Speed Rating
1667x/1867x
SD Speed Class
UHS Class 3
Read Rate
Up to 280 MB/s
Write Rate
Up to 250 MB/s
Shockproof, waterproof, X-ray-proof
Software Included
-25 °C
85 °C
Scroll to top
