BT.com
Wishlist
Samsung Xpress M2885FW Mono Laser Multifunction Printer
Delivery
Standard Due date unavailable
No more waiting. Samsung's high-performance Xpress M2885FW multi-function printer delivers great results while cutting costs. Print wirelessly and share effortlessly with the Samsung Xpress M2885FW. All it takes is a simple tap with its advanced NFC technology, and the Samsung Mobile Print App allows you to take advantage of the powerful mobile features. Simply tap your NFC-enabled mobile device to the Samsung Xpress M2885FW to quickly and easily establish a Wi-Fi direct connection, so you can print virtually any content from your smartphone or tablet.
Samsung Xpress M2885FW - multifunction printer (B/W)
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
12000 impressions
Max Copying Speed
Up to 28 ppm
Max Printing Speed
Up to 28 ppm
Max Printing Resolution
Up to 4800 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 1200 dpi
Original Size
142 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
40 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, thin paper, thick paper, cotton paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
120 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
Office Machine Features
Scan to folder
40.1 cm x 36.2 cm x 36.7 cm
11.3 kg
Environmental Standards
ENERGY STAR Qualified, EPEAT Bronze
Fax Type
Plain paper
Printing Technology
Laser - monochrome
12000 impressions
Display
2 lines
Scan to folder
Standard Memory
128 MB
Copying
Max Copying Speed
Up to 28 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Up to 28 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, SPL
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 600 pages
Fax Machine Features
Fax forwarding, automatic redialing, last number redial, multi-send, delayed sending
Document & Media Handling
Min Original Size
142 x 148 mm
Max Original Size
Original Type
Sheets
40 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
120 sheets
ADF - 40 sheets size: 142 x 148 mm - Legal (216 x 356 mm) , Paper cassette - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 120 sheets
Speed Details
Printing: up to 28 ppm (A4) - B/W , Printing: up to 29 ppm (Letter A) - B/W , Copying: up to 28 ppm (A4) - B/W , Copying: up to 29 ppm (Letter A) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Apple Mac OS X 10.5 - 10.9
400 Watt
Power Consumption Standby
50 Watt
First Copy Out Time B/W
14 sec
Consumables Included
1 x Cartridge (black) - up to 1200 pages
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
40.1 cm
36.2 cm
36.7 cm
11.3 kg
Sound Emission
26 dBA (idle) / 53 dBA (operating)
Scroll to top
