BT.com
Wishlist
Samsung Wireless Soundbar Black 3.1 Channel
Samsung Wireless Soundbar Black 3.1...
£284.96
18 in stock
£284.96
Add to wishlist
Delivery
Standard 1-3 working days
Specifically constructed with a larger speaker capacity, improved active crossover and a dedicated center speaker, the HW-K550 provides an amazing vocal clarity. Six built-in speakers give this soundbar the depth and power to deliver a warm and detailed audio experience. You can power on your audio system and control it from your smartphone with Bluetooth. After an initial pairing, you can quickly find the devices you want, wake them up and stream your music.
Samsung HW-K550 - sound bar system - for home theatre - wireless
Sound bar system - home theatre - 3.1-channel
Integrated Components
USB host
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
340 Watt
Audio Amplifier
Integrated
Connectivity Interfaces
Bluetooth
Supported Digital Audio Standards
WAV, WMA, AAC, MP3, FLAC, OGG
Speaker System Details
1 x sound bar 180 Watt , 1 x subwoofer 160 Watt 3 Ohm
Speaker Details
Sound bar - stereo - 2 x 60 Watt - 10% THD - 6 Ohm - active , Sound bar - centre channel 60 Watt - 10% THD - 6 Ohm - active
Built-in Decoders
Dolby Digital, DTS decoder, SBC decoder, DTS Digital Surround
Sound Effects
Surround Sound Expansion
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Sound bar system - for home theatre - 3.1-channel
USB host
Dimensions (WxDxH) / Weight Details
Sound bar: 1.0105 m x 8.75 cm x 5.4 cm / 2.6 kg , Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg
Enclosure Colour
Speaker System
System Components
Speaker Type
Active
340 Watt
Audio Amplifier
Integrated
Sound Effects
Bluetooth
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Built-in Decoders
Controls
Input selector, power on/off, volume
Speakers Included
1 x sound bar - 180 Watt - wall-mountable - wireless , 1 x subwoofer - 160 Watt - 3 Ohm - wireless
Speaker Details
Driver Details
Subwoofer: 1 x subwoofer driver - 7"
Connector Type
HDMI input ( 19 pin HDMI Type A ) , HDMI output ( 19 pin HDMI Type A ) , USB ( 5 pin Micro-USB Type B ) , Audio line-in ( mini-phone stereo 3.5 mm ) , Digital audio input (optical) ( TOS Link )
Remote control, audio (optical) cable, wall mounting bracket
Power Source
AC power adapter
53 Watt
Limited warranty - parts and labour - 1 year
Scroll to top
