BT.com
Wishlist
Samsung Wireless Soundbar, 3.1 Channel - Silver
Samsung Wireless Soundbar, 3.1...
£295.45
Colours:
£295.45
Add to wishlist
Delivery
Standard 1-3 working days
Experience crystal clear dialog with a dedicated center speaker on the Soundbar. It provides balanced sound from one end of the bar to the other and angles the sound so that voices seem to emanate from the screen. The Soundbar was designed with 6 separate speakers, each with its own dedicated amplifier, to provide clear and accurate sound. The Wireless Surround Kit lets you easily expand your surround sound system, and without the tangle of wires. Together with your Soundbar, you can create a 5.1 channel system for a true surround sound experience. TV SoundConnect helps bring your home entertainment system together with your TV with ease and without the clutter of wires. You'll be able to enjoy all your content instantly with clearer, more impactful sound. With its convenient wireless design, the subwoofer is incredibly easy to set up anywhere, quickly giving you the freedom to enjoy supersonic bass quality and a fully natural sound experience. Feel the sound and get into the action with stunningly realistic HD audio. It preserves the quality and richness of the original sound using 192 kHz/24-bit sampling. Now you can power on your audio system and control it from your smartphone with Bluetooth. After an initial pairing, you can quickly find the devices you want, wake them up, and stream your music. The Soundbar uses Bluetooth for easy wireless connections to other devices. Enjoy music from your mobile or PC in top audio quality anywhere, no strings attached.
Samsung HW-K551 - sound bar system - for home theatre - wireless
Sound bar system - for home theatre - 3.1-channel
Integrated Components
USB host
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
340 Watt
Audio Amplifier
Integrated
Connectivity Interfaces
Bluetooth
Supported Digital Audio Standards
WAV, WMA, AAC, MP3, FLAC, LPCM, OGG
Speaker System Details
1 x sound bar 180 Watt , 1 x subwoofer 160 Watt 3 Ohm
Speaker Details
Sound bar - stereo - 2 x 60 Watt - 10% THD - 6 Ohm - active , Sound bar - centre channel 60 Watt - 10% THD - 6 Ohm - active
Silver
Built-in Decoders
Dolby Digital, DTS decoder, DTS Digital Surround
Sound Effects
Surround Sound Expansion
Environmental Standards
ENERGY STAR Qualified
USB host
Dimensions (WxDxH) / Weight Details
Sound bar: 1.0105 m x 8.75 cm x 5.4 cm / 2.6 kg , Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg
Enclosure Colour
Silver
Speaker System
System Components
Speaker Type
Active
340 Watt
Audio Amplifier
Integrated
Sound Effects
Bluetooth
Built-in Decoders
Controls
EQ mode selector, power on/off, volume
Speakers Included
1 x sound bar - 180 Watt - wall-mountable - wireless , 1 x subwoofer - 160 Watt - 3 Ohm - wireless
Speaker Details
Driver Details
Subwoofer: 1 x subwoofer driver - 7"
Connector Type
HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , USB (5 pin Micro-USB Type B) , Audio line-in , Digital audio input (optical) (TOS Link)
Remote control, wall mounting bracket
Power Source
AC power adapter
53 Watt
Scroll to top
