BT.com
Wishlist
Samsung Wireless PTZ Camera & Monitor
Samsung Wireless PTZ Camera &...
£126.50
£126.50
Add to wishlist
Delivery
Standard Due date unavailable
The Samsung SEW-3037W is an easy to use wireless baby monitoring system consisting of a high resolution 3.5" LCD monitor and wireless "night vision" camera with non-visible IR LEDs ensure safe night time monitoring. The camera unit features VGA (640 x 480) resolution to provide crisp and clear image and built-in mic and speaker of the camera allows two-way talk and you can talk to and hear your baby.
The SEW-3037W ensures long range transmission up to 900ft, allows you to monitor your baby at a distance. The monitor unit has LED on its front panel which indicates the level of sound so that you do not miss sound from your baby. And the pan and tilt of the camera can be operated from a parent unit with the button on the monitor so that you can adjust the view remotely. Up to 4 cameras can expanded with a monitor unit, the SEW-3037W will be a perfect solution to care the safety of your baby.
SAMSUNG TECHWIN SafeVIEW SEW-3037W - baby monitoring system - wireless
System
Baby monitoring system - wireless - 2.4 GHz
Monitor
3.5" LCD monitor (TFT) - colour
Camera
1 cameras - indoor - PAL - night vision
167 g
System
Wireless Frequency Band
2.4 GHz
2-way audio, volume control, built-in microphone, Vox (Voice activated transmission)
Package Content
Camera, 2 power adapters, Monitor
Monitor
Diagonal Size
3.5"
LCD monitor
LCD Technology
TFT
Image Resolution
320x240
Cameras
Quantity
1 cameras
Camera Type
Indoor
Sensor
CMOS - 1/5" - 640x480
Field Of View
56 degrees
TV System
PAL
Sensitivity (lux)
2
Night Vision
Infrared LEDs
White Balance
Auto
Focal Length
3 mm
Voltage
DC 6 V
Current Consumption
320 mA
-10 °C
Operating Humidity
0-85%
167 g
Details
Camera: 214 g , Monitor: 167 g
Scroll to top
