BT.com
Wishlist
Samsung WB150 - Digital camera - compact - 14.2 Mpix - 18 x optical zoom - Schneider - white
Delivery
Standard Due date unavailable
Smart technology for shooting and sharing
  • Get closer to the action with 18x optical zoom
  • Capture wider shots with 24mm ultra-wide angle lens
  • Shoot with full control using Full Manual Mode
  • See it all on a super-bright 3.0" hVGA LCD display
Indoors or outside, up close or far away - with the Samsung WB150, you're always ready to capture life's special moments as they happen, so you can treasure them forever. The 24mm ultra-wide lens and 18x optical zoom ensure you capture exactly what you want in the frame. Samsung's 14.2 megapixels means that even the smallest details will be reproduced with professional quality. Whether you're shooting stills or recording 720p HD video - the WB150 lets you relive memories perfectly.
Take your vision much further and clearer
18x Optical Zoom, OIS
When your child reaches the top of the adventure playground for the first time, you'll get a great view of the moment - and so does your new Samsung WB150. With its 18x Optical Zoom, it brings the intimate details closer, so you can capture the smiles just as you want to remember them. Whether wide-open vistas or detailed close-ups, the WB150 lets you get the shot you want. But it has to be steady too. That's where the WB150's OIS (Optical Image Stabilisation) comes in handy. The very second you shoot, the image is stabilised. So no matter how shaky your hands are, your photos won't be.
Get a whole new view
24mm Wide angle lens
Get more from your lens, no matter what the scene, whether shooting a memorable landscape or a friends' reunion around a restaurant table. By using the precision-cut WB150's 24mm wide-angle lens, you will instantly cover a whole-horizon field of view. Now, you can capture memories of landmarks and landscapes, entire wedding parties and the tallest skyscrapers in full scale. No need to back up to frame the shot.
Get full control
Full Manual Mode (A / S / M)
Full Manual gives you the ability to take complete control and capture the photos exactly as you want them to be. Aperture Priority and Shutter Priority settings let you experiment with shutter speeds and depth of field, so you can shoot fast-moving images in low light. With Samsung cameras, your creativity counts most.
When it comes to brightness, it's brilliant
3" hVGA LCD
Its 3" hVGA LCD provides improved contrast and colour reproduction, which allows you to enjoy a wider and clearer image. And its hVGA LCD brightness automatically detects environmental illumination and adjusts the LCD brightness for optimal image viewing. It does the thinking for you, which makes the WB150 a smart choice.
Make your own movies
720p HD Movie Recording, H.264
The WB150 artfully combines a professional-grade still camera with a compact HD video camera. You get 720p HD quality video at 30 frames per second and 4x longer recording time than MJPEG video. Use the 18x zoom to get up close and vividly personal. SoundAlive, with special zoom noise reduction technology, ensures you crystal-clear, vibrant sound recordings.
The simple way to go pro
Smart Auto 2.0
Smart Auto 2.0 turns fleeting moments into perfect memories with professional-style results. Whether it's friends at last night's party or moonbeams reflecting off the water, Smart Auto 2.0 (still and movie) analyses key elements in the composition and automatically adjusts its 16 photo modes and 4 movie modes to capture the best shot. And since life never stops moving, the camera's object tracking feature captures subjects that just won't stand still.
See all of it before you shoot it all
Live Panorama
With Live Panorama, you can practically capture the whole wide world without having to step back! Live Panorama lets you see the final image in advance, so you know you're getting the picture you want. It's as simple as holding down the shutter button and sweeping the camera across the scene.
Show both sides of the story
PIP (Still / Movie)
A Picture in Picture Shot lets you iinsert one image or movie within another to capture the full, glorious story you want to share. Snap a picture of a friend bowling a strike, and then combine it with an image of everyone cheering the score.
Combine images, create fun
Split Shot
With Split Shot, you can merge up to three different images to create an artistic statement - turn yourself into a centaur by combining a self-portrait with a picture of a horse. Let your imagination loose and enjoy fun.
More fun, More creative
Smart Filter 3.0
Boost creative fun with the Smart Filter 3.0 -right on the display! Cartoon filter makes any photo look like an animated film scene while Cross Filter makes light sources appear to have several points of light, like stars. There's also Ink Painting, Half-tone Dot and more ways for you to express your creative side.
Samsung WB150 - digital camera - Schneider
Digital camera - 720p - compact
Lens Included
Schneider
Memory Card Slot
SD card
Sensor Resolution
14.2 Megapixel
Max Video Resolution
1280 x 720
Lens System
18 x zoom lens - 4 - 72 mm - f/3.2-5.8
Focus Adjustment
Automatic, manual
Min Focus Distance
80 cm
Digital Zoom
5 x
Image Stabiliser
Optical
Camera Flash
Built-in flash
Display
LCD display - 3"
Supported Battery
1 x Samsung SLB-10A Li-ion rechargeable battery ( included )
Interfaces Provided
Composite video/audio, USB 2.0
White
10.7 cm x 23.4 cm x 6 cm
188 g
Lens Included
Schneider
Enclosure Colour
White
Sensor Resolution
14.2 Megapixel
Optical Sensor Type
CCD
Total Pixels
16,400,000 pixels
Effective Sensor Resolution
14,200,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
3200
Optical Zoom
18 x
Digital Zoom
5 x
Image Stabiliser
Optical
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Face Detection AF/AE, face-priority AF function
Digital Video Format
H.264
Image Recording Format
JPEG
1280 x 720
Interfaces Provided
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 3200, ISO auto
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Portrait mode, action, macro, text, backlight, beach/snow, night portrait, Blue Sky, scenery, fireworks, panorama assist, night scene, sunset, foliage, dawn, tripod, white, macro text, magic frame
Special Effects
Old Movie, fisheye, soft focus, Sketch, miniature, Cartoon, Classic, Retro, cross filter, Paint
Retouch
Face retouch
White Balance
Custom, automatic, presets
White Balance Presets
Cloudy, tungsten light, daylight, fluorescent light (cool white), fluorescent light (warm white)
Exposure Compensation
±2 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps
Lens System
Schneider 18 x zoom lens - 4 - 72 mm - f/3.2-5.8
Focal Length Equivalent to 35mm Camera
24 - 432mm
Focus Adjustment
Automatic, manual
Min Focus Distance
80 cm
Macro Focus Range
5cm
Zoom Adjustment
Motorised drive
Built-in lens shield
Camera Flash
Camera Flash
Built-in flash
Additional Features
Self Timer Delay
10 sec, 2sec
Additional Features
Built-in speaker, date/time stamp, sharpness control, digital image rotation, saturation control, brightness control, Auto Contrast Balance (ACB), Smart AUTO
Display
3" LCD display
Resolution
460,000 pixels
Display Form Factor
Built-in
Display Features
Contrast control
Microphone
Microphone Operation Mode
Mono
Connector Type
1 x USB 2.0 , 1 x composite video/audio output
Software
Software
Drivers & Utilities, Samsung Intelli Studio
Battery Type
Samsung SLB-10A
Details
Memory / Storage
RAM Installed
18 MB
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 4320 x 3240 , JPEG 4320 x 2880 , JPEG 4320 x 2432 , JPEG 3648 x 2736 , JPEG 2832 x 2832 , JPEG 2592 x 1944 , JPEG 1984 x 1488 , JPEG 1920 x 1080 , JPEG 1024 x 768
Video Capture
H.264 - 1280 x 720 - 30 fps , H.264 - 1280 x 720 - 15 fps , H.264 - 640 x 480 - 30 fps , H.264 - 640 x 480 - 15 fps , H.264 - 320 x 240 - 30 fps , H.264 - 320 x 240 - 15 fps
10.7 cm
23.4 cm
6 cm
188 g
5 - 85%
Scroll to top
