BT.com
Wishlist
Samsung WAM751 Wireless Audio Multiroom Bluetooth Speaker - White
Delivery
Standard Due date unavailable
The Samsung Shape M7 supports dual-band Wi-Fi, which ensures an uninterrupted stream across virtually any device. Additionally, Multi-Channel Mesh Network technology prevents network traffic problems by automatically searching for and finding clear audio data paths. Compatible with a variety of apps including Amazon Cloud Player, Pandora, Rhapsody, TuneIn Radio and more, the system can be customized to play different music in different rooms, or the same music throughout the home. Customers can also access content from their own library of music whether it is stored on a smartphone, a laptop or a PC.
The Samsung Shape M7 offers visual harmony within any room environment. Its unique design affords a wide variety of placement choices allowing it to fit snugly in the corner of the wall as if it were custom-designed for the space. It can also be positioned vertically or horizontally for maximum versatility. Wherever the user decides to put the unit - on a table, on a shelf or hanging on the wall with the optional wall mount kit, the system's minimalist design and wire-free aesthetics will feel right at home in any décor.
Samsung SHAPE M7 - speaker - wireless
Speaker
Internet radio
Speaker Type
Active
Amplifier
Integrated
Fast Ethernet, Bluetooth, Wi-Fi, NFC
DLNA
Audio Formats
WAV, WMA, AAC, AIFF, MP3, FLAC, Apple Lossless, OGG
White
Built-in Decoders
Dolby Digital, DTS decoder
40.2 cm x 13.7 cm x 19.4 cm
3.8 kg
Speaker
Internet radio
Enclosure Colour
White
Speaker System
Speaker Type
Active
Signal-To-Noise Ratio
65 dB
Amplifier
Integrated
IEEE 802.3u (Fast Ethernet), Bluetooth, Wi-Fi, Near Field Communication (NFC)
DLNA
Recommended Placing
Wall-mountable, table-top
Built-in Decoders
Audio Formats
Additional Features
Samsung AllShare technology, software update via USB, smartphone remote controlled, TV SoundConnect technology
Speaker System Details
Driver Details
Speaker: woofer driver - 4" , Speaker: 2 x tweeter driver - 0.75" , Speaker: 2 x mid-range driver - 2.2"
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , LAN (RJ-45)
Power adapter, stand
Power Source
AC power adapter
24 Watt
40.2 cm
13.7 cm
19.4 cm
3.8 kg
Scroll to top
