BT.com
Wishlist
Samsung UE46D 46" 1920x1080 VGA DVI HDMI DisplayPort SOC LED Large Format Display
Price Drop
Price Drop - Save over £140
Delivery
Standard Due date unavailable
The Samsung UE46D features a stylishly thin chassis with a slim 11mm bezel to bezel spec, combined with an upgraded Samsung SMART Signage Platform. Create beautiful video walls in full HD with no PC, DVD or SBB required. Built-in Wi-Fi allows for easy mobile control and increased Daisy Chain capability.
Samsung UE46D UE-D Series - 46" LED display
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
225
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery, Lamp Error Detection
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card
USB
Remote Control
Standard remote
Voltage
Energy Class
Class C
132 Watt
Power Consumption (On mode)
120 W
Energy Consumption per Year
175 kWh
103.09 cm x 3.13 cm x 58.54 cm
10 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class C
132 Watt
120 W
175 kWh
Diagonal Class
46"
Commercial Use
Series
UE-D Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Design
Narrow Bezel Design
225
Dimensions
Without stand
103.09 cm
3.13 cm
58.54 cm
10 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Brightness
450 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.17675 x 0.53025mm
Response Time
4 ms
Commercial Features
Pivot, Multiple Display Control (MDC), digital daisy chain, Smart Scheduling, e-LED BLU, MagicInfo Player-S2
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
SD Memory Card
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - built-in - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback
Wi-Fi
Connector Type
Serial input , Serial output , Remote control/ambient sensor input , Audio line-in , Audio line-out , USB 2.0 , HDMI input , DisplayPort input , DisplayPort output , DVI-D input , VGA input , Composite video / component video / audio input , Network , Remote control output
DisplayPort cable
Plug and Play, TUV, C-Tick, GOST, cUL, DDC-2B, EN 60950, EN55022, NOM, PCBC, SASO, SIQ, IEC 60950, EN55024, UL 60950, CISPR 22, CB, CCC, EMC, PSB, EK, AS/NZS 3548, IRAM, BSMI CNS 13438, FCC Part 15 B Class A, VCCI V-3, GB 9254-2008, GB 17625.1-2003 EMC, KCC KN22, KCC KN24, K60950, GB 4943.1, IS13252, NOM-001-SCFI-1993, BIS
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
111 cm
Depth (Shipping)
13 cm
Height (Shipping)
66.8 cm
Weight (Shipping)
13 kg
10 - 80%
Scroll to top
