BT.com
Wishlist
Samsung UD55E-P 55" 1920x1080 VGA DVI HDMI LED Large Format Display
Samsung UD55E-P 55" 1920x1080 VGA...
£4,194.96
12 in stock
£4,194.96
Add to wishlist
Delivery
Standard 1-3 working days
Samsung's UDE Series video wall, UDE-P, features advanced factory tuning, innovative hardware and exceptional user calibration tools. Samsung's multi-step factory calibration process tunes video wall displays to the highest-performing uniform brightness and color across each display out-of-the-box. The enhanced panel quality of Samsung's UDE-P video wall elevates visual messaging and content through a seamless image and superior clarity. Featuring an ultra-narrow 3.5 mm bezel-to-bezel design format (2.3 mm bezel on the left and top sides and 1.2 mm bezel on the right and bottom sides), which is the slimmest bezel in the video wall industry, the display creates a virtually uninterrupted viewing experience to keep audiences focused on content rather than the display itself. Businesses face increased challenges to capture the attention of passers-by with impactful content, particularly in large, often crowded retail and public environments. By combining the ultimate in picture quality with unparalleled multiscreen display connectivity, the Samsung UDE-P video wall garners heightened exposure for messaging by captivating viewers. The display transforms standard Full-High Definition (FHD) content into a powerful Ultra-High Definition (UHD) viewing experience for the enhanced effectiveness and impact of message deployment. Featuring integrated DisplayPort (DP) 1.2 ports, the UDE-P can showcase high-quality UHD content across multiple screens simultaneously without requiring additional external devices. This improved capability and flexibility generates opportunities for businesses to share memorable content without adding cost or complexity. As an all-in-one solution, the Samsung UDE-P video wall ensures users can create, deploy and manage an array of highly-impactful content without separate external PCs or devices. With a built-in media player through its embedded chip, 3rd Generation SSSP, the UDE-P uses its powerful Quad Core CPU to streamline digital content operation and improve total cost of ownership (TCO). As a result, content managers can easily install the video wall and begin sharing content with target audiences with minimal expense or hassle. Samsung's versatile UDE-P Series video walls come equipped with a range of user-friendly features to ensure a seamless installation complementary to your specific operational needs. The displays come with an industry-leading slim, 39 mm depth video wall mount for easy installation and calibration to hold each display in place without distracting viewers. As the wall mount is sized to the dimensions of the video wall, users can simply install the mount first and fit into the video wall. This user-friendly design eliminates the need to measure the wall mount and calculate the gap to properly size, which can be experienced with standard video wall mounting systems.
Samsung UD55E-P UDE-P Series - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Commercial Features
Advanced Color Management (ACM), Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
USB
Remote Control
Standard remote
Voltage
297 Watt
121.53 cm x 9.66 cm x 68.43 cm
23.3 kg
Environmental Standards
ENERGY STAR Qualified
297 Watt
Diagonal Class
55"
Commercial Use
Series
UDE-P Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
100
Dimensions
Without stand
121.53 cm
9.66 cm
68.43 cm
23.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
10000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63 x 0.63mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), digital daisy chain, MagicInfo, Smart Scheduling, key lock, MagicInfo Player-S3
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Connector Type
VGA input , DVI-D input , DisplayPort input , DisplayPort output , Composite video / component video / audio input , 2 x HDMI input , Audio line-in , Audio line-out , Remote control
Batteries
DisplayPort cable
Plug and Play, TUV, C-Tick, BSMI, GOST, DDC-2B, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, PSB, AS/NZS 3548, UL 60950-1, KCC, BSMI CNS 13438, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, KN22, KN24, K60950-1, GB4943.1-2011, GB 17625.1-2012, IEC60950-1
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
Width (Shipping)
145 cm
Depth (Shipping)
38.5 cm
Height (Shipping)
90.3 cm
Weight (Shipping)
36.9 kg
10 - 80%
Scroll to top
