BT.com
Wishlist
Samsung UD55D 55" 1920x1080 VGA DVI HDMI DP VESA 700CD LED LFD
Samsung UD55D 55" 1920x1080 VGA DVI...
£1,835.29
£1,835.29
Add to wishlist
Delivery
Standard Due date unavailable
Samsung UD55D LFD with FHD can take your digital messaging to the next level thanks to unsurpassed Samsung bezel innovation. This 3.5 mm bezel display can amaze audiences when combined together to form seamless video walls with virtually no visual distraction. From 4 meters (13 feet) away UD55D bezel is invisible to the naked eye creating a truly uninterrupted image for optimized visual messaging. Use this display technology to entice customers into your retail shop, replace traditional whiteboards in your corporate meeting room or provide important real-time information in public places. Additionally, provide highly bright, vibrant picture quality without glare or blurriness to completely captivate audiences with a powerful viewing experience.
Deliver your messages in consistently accurate color across multiple displays with Samsung UD55D LFD. The display undergoes a meticulous factory color calibration process, ensuring accurate color without image distortion without the need for manual calibration. The improved factory color-tuning for white balancing and color difference compensation ensure that the display presents image in uniform color with color temperature matching. For users who want to fine-tune the colors, Samsung advanced color management offers more detailed management. Color vibrancy can be calibrated automatically or manually. Color values can be shared between multiple displays, ensuring outstanding intensity across all video wall screens that can impress the audience. Combined with the anti-glare panel that reduces light scatter to make messages more readable, UD55D LFD can effectively deliver your content in the vibrant, accurate color to impress your audience.
Samsung UD55D UD-D Series - 55" LED display
LED-backlit LCD flat panel display with built-in PC
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight - direct-lit LED
TV Tuner
No tuner
Commercial Features
SMART Signage Platform, Image Rotation, Magic Clone
Storage Drive Capacity
8 GB
USB
Remote Control
Standard remote
Voltage
AC 120/230 V ( 50/60 Hz )
Energy Class
Class C
209 Watt
Power Consumption (On mode)
180 W
Energy Consumption per Year
263 kWh
121.35 cm x 9.66 cm x 68.43 cm
23.3 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class C
209 Watt
180 W
263 kWh
Diagonal Class
55"
Commercial Use
Combined with
Built-in PC
Series
UD-D Series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
100
Dimensions
Without stand
121.35 cm
9.66 cm
68.43 cm
23.3 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Colour Depth
16.7 million colours
Image Contrast Ratio
3500:1
Dynamic Contrast Ratio
10000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63mm
Response Time
8 ms
Commercial Features
Pivot, digital daisy chain, MagicInfo Lite, Advanced Color Management, MagicInfo Premium-S, MagicInfo Videowall-S
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
1
PC Configuration
ARM Cortex-A9 / 1 GHz / 1 GB DDR3
8 GB
Remote Control
Standard remote
Connector Type
2 x HDMI input , Composite video / component video / audio input , DVI-D input , VGA input , Audio line-out , Serial input , Multiple Display Control , USB 2.0 , DisplayPort input , Serial output , DisplayPort output , Audio line-in
VGA cable
Plug and Play, DDC-2B, ISO 9241-307
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - parts and labour - 3 years - on-site
Width (Shipping)
145 cm
Depth (Shipping)
38.5 cm
Height (Shipping)
90.3 cm
Weight (Shipping)
36.9 kg
Scroll to top
