BT.com
Wishlist
Samsung UD55C-B 55" 1920x1080 VGA DVI HDMI DisplayPort SOC LED Large Format Display
Samsung UD55C-B 55" 1920x1080 VGA...
£1,576.15
£1,576.15
Add to wishlist
Delivery
Standard Due date unavailable
Therobust and reliable Samsung UDC-B LFD series displays enable businesses to convey their messages with vivid color accuracy. Astound your viewers with consistently brilliant imagery and color across all displays in the video wall, delivered on a near-seamless canvas with a super-narrow bezel of 5.5 mm. With UDC-B series displays, you can use the display solution of your choice on the video wall to deliver your content in the optimal way you want. For even greater impact, creatively configure the video wall to captivate your audience. Retailers and entertainment venues may showcase a more artistic configuration, while control centers and corporations may display a more standard video wall. Regardless of setup, your message will dazzle audiences on a bright, sleek, energy-efficient video wall.
Samsung UD55C-B UDC-B Series - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight - direct-lit LED
TV Tuner
No tuner
Commercial Features
Button lock, Auto Source Switching & Recovery, Lamp Error Detection
Remote Control
Standard remote
AC 120/230 V ( 50/60 Hz )
Energy Class
Class B
165 Watt
Power Consumption (On mode)
155 W
Energy Consumption per Year
226.3 kWh
121.53 cm x 11.38 cm x 68.61 cm
24.3 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
165 Watt
155 W
226.3 kWh
Diagonal Class
55"
Commercial Use
Series
UDC-B Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
100
Dimensions
Without stand
121.53 cm
11.38 cm
68.61 cm
24.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Colour Depth
16.7 million colours
Image Contrast Ratio
3500:1
Dynamic Contrast Ratio
10000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63 x 0.63mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), digital daisy chain, Anti Retention, Smart Scheduling, Advanced Color Management
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Standard remote
Connector Type
VGA input , DVI-D input , 2 x HDMI input , Component video input , Composite video input , Audio line-in , DVI-D output , Audio line-out , Serial , Remote control , Remote control/ambient sensor input
VGA cable
Plug and Play, CSA, UL, TUV, C-Tick, BSMI, GOST, DDC-2B, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, AS/NZS 3548, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, BSMI CNS 13438, FCC Part 15 B Class A, CAN/CSA C22.2 No. 60950-1, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, GB 17625.1-2003 EMC, KN22, KN24, K60950-1
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0 Watt
Width (Shipping)
144 cm
Depth (Shipping)
37.5 cm
Height (Shipping)
87 cm
Weight (Shipping)
35.1 kg
10 - 80%
Scroll to top
