BT.com
Wishlist
Samsung UD55C 55" 1920x1080 VGA DVI HDMI DP VESA 700CD LED LFD
Delivery
Standard Due date unavailable
UD-C series displays are factory tuned for brightness, color temperature and gamma. They deliver optimal uniformity and impressive images right out of the box.
The minimized bezel gap of just 5.5 mm is crucial to the virtually seamless video wall experience that the UD-C series delivers. It's ideal for control rooms, the medical sector, and conference rooms, broadcasting stations, transportation hubs, lobbies and retail.
Samsung UD55C UD-C Series - 55" LED display
LED-backlit LCD flat panel display with built-in PC
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight - direct-lit LED
TV Tuner
No tuner
Commercial Features
SMART Signage Platform, Image Rotation, Magic Clone
Settings Cloning Capability
Storage Drive Capacity
2.8 GB
USB
Remote Control
Standard remote
Voltage
Energy Class
Class C
220 Watt
Power Consumption (On mode)
175 W
Energy Consumption per Year
256 kWh
121.53 cm x 9.6 cm x 68.61 cm
24 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class C
220 Watt
175 W
256 kWh
Diagonal Class
55"
Commercial Use
Combined with
Built-in PC
Series
UD-C Series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
100
Dimensions
Without stand
121.53 cm
9.6 cm
68.61 cm
24 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Colour Depth
16.7 million colours
Image Contrast Ratio
3500:1
Dynamic Contrast Ratio
10000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63mm
Response Time
8 ms
Commercial Features
Pivot, Certified for 24/7 Continuous Operation, MagicInfo Lite, DID technology, Dual-Core processor, Advanced Color Management, MagicInfo Premium-S, MagicInfo Videowall-S, d-LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
1
PC Configuration
ARM Cortex-A9 / 1 GHz / 1 GB DDR3
2.8 GB
Remote Control
Standard remote
Connector Type
2 x DisplayPort , 2 x HDMI , DVI-Digital , VGA input , Composite video input , Component video input , Serial , Remote control , Audio line-out , Audio line-in , USB 2.0
VGA cable
Plug and Play, DDC-2B, ISO 9241-307
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years - on-site
Width (Shipping)
145 cm
Depth (Shipping)
38.5 cm
Height (Shipping)
90.3 cm
Weight (Shipping)
41.6 kg
Scroll to top
