BT.com
Wishlist
Samsung UD46D-P 46" 1920x1080 VGA DVI HDMI DisplayPort SOC LED Large Format Display
Delivery
Standard Due date unavailable
Samsung UD46D-P SMART signage with FHD can take your digital messaging to the next level thanks to unsurpassed Samsung bezel innovation. These never before seen bezel displays can amaze audiences when combined together to form seamless video walls with virtually no visual distraction. The UD46D-P bezels are invisible to the naked eye creating a truly uninterrupted image for optimized visual messaging. Use this cutting-edge display technology to entice customers into your retail shop, replace traditional whiteboards in your corporate meeting room or provide important real-time information in public places. Additionally, provide highly bright, vibrant picture quality without glare or blurriness to completely captivate audiences with a powerful viewing experience.
Samsung UD46D-P UD-D Series - 46" LED display
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight - direct-lit LED
TV Tuner
No tuner
Commercial Features
Button lock, Image Rotation, Magic Clone, Auto Source Switching & Recovery, Lamp Error Detection, SMART Signage Platform 2nd Generation
Settings Cloning Capability
Supported Memory Cards
SD Memory Card
USB
Remote Control
Standard remote
Voltage
Energy Class
Class C
Power Consumption (On mode)
130 W
Energy Consumption per Year
190 kWh
102.21 cm x 9.7 cm x 57.67 cm
18 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class C
130 W
190 kWh
Diagonal Class
46"
Commercial Use
Series
UD-D Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
100
Dimensions
Without stand
102.21 cm
9.7 cm
57.67 cm
18 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Coating
Anti-glare
Colour Depth
16.7 million colours
Image Contrast Ratio
3500:1
Dynamic Contrast Ratio
10000:1
Brightness
700 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.53025 x 0.53025mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), digital daisy chain, Anti Retention, MagicInfo, DID technology, Smart Scheduling, Advanced Color Management, MagicInfo Videowall-S, MagicInfo Player-S2
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Media Player
SD Memory Card
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Network & Internet Multimedia
Wi-Fi, LAN
Connector Type
2 x HDMI input , Composite video / component video / audio input , DVI-D input , VGA input , Audio line-out , Serial input , Multiple Display Control , USB 2.0 , DisplayPort input , Serial output , DisplayPort output , Audio line-in
DisplayPort cable
Plug and Play, FCC Class B certified, CSA, UL, TUV, C-Tick, BSMI, GOST, DDC-2B, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, FCC Part 15 B, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, EN 60950-1, ISO 9241-307, KCC, CSA C22.2 No. 60950-1, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, KN22, KN24, K60950-1, CNS 13438, IEC60950-1, GB 17625.1-2011, GB4943.1-2001
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
125.5 cm
Depth (Shipping)
35.5 cm
Height (Shipping)
79.8 cm
Weight (Shipping)
22.4 kg
10 - 80%
Scroll to top
