BT.com
Wishlist
Samsung UD46C-B 46" 1920x1080 VGA DVI HDMI DisplayPort VESA 450CD LED Large Format Display
Delivery
Standard Due date unavailable
UD-C series displays are factory tuned for brightness, color temperature and gamma. They deliver optimal uniformity and impressive images right out of the box.
The minimized bezel gap of just 5.5 mm is crucial to the virtually seamless video wall experience that the UD-C series delivers. It's ideal for control rooms, the medical sector, and conference rooms, broadcasting stations, transportation hubs, lobbies and retail.
Samsung UD46C-B UDC-B Series - 46" LED display
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Remote Control
Standard remote
Voltage
Energy Class
Class C
130 Watt
Power Consumption (On mode)
120 W
Energy Consumption per Year
175 kWh
102.37 cm x 9.55 cm x 57.83 cm
18.2 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class C
130 Watt
120 W
175 kWh
Diagonal Class
46"
Commercial Use
Series
UDC-B Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
100
Dimensions
Without stand
102.37 cm
9.55 cm
57.83 cm
18.2 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Colour Depth
16.7 million colours
Dynamic Contrast Ratio
3500:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.53025 x 0.53025mm
Response Time
6.5 ms
Certified for 24/7 Continuous Operation, Lamp Error Detection, anti-image retention
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Standard remote
Connector Type
VGA input , DVI-D input , 2 x HDMI input , Component video input , Composite video input , Audio line-in , DVI-D output , Audio line-out , Serial , Remote control , Remote control/ambient sensor input
VGA cable
Plug and Play, CSA, UL, TUV, C-Tick, BSMI, GOST, DDC-2B, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, AS/NZS 3548, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, BSMI CNS 13438, FCC Part 15 B Class A, CAN/CSA C22.2 No. 60950-1, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, GB 17625.1-2003 EMC, KN22, KN24, K60950-1
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years
Width (Shipping)
125.5 cm
Depth (Shipping)
35.5 cm
Height (Shipping)
79.8 cm
Weight (Shipping)
31.2 kg
10 - 80%
Scroll to top
