BT.com
Wishlist
Samsung UD22B 22" 1920x1080 VGA DVI HDMI DisplayPort LED Large Format Display
Samsung UD22B 22" 1920x1080 VGA DVI...
£2,557.74
£2,557.74
Add to wishlist
Delivery
Standard Due date unavailable
The UD22B can be configured in video walls up to 10 x 10 for strikingly different and artistic messaging that draws customer attention. Smart scheduling enables video wall content control at all times with up to 3 programmable day/time calendars. The upgraded multi display control allows control of multiple monitors through the embedded RS232C and RJ45 interfaces.
Samsung UD22B 22" Class (21.6" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
22"
Diagonal Size
21.6 in
Commercial Use
Yes - digital signage
Resolution
960 x 960
Video Interface
Composite, HDMI
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
1:1
TV Tuner
No tuner
Sound Output Mode
Stereo
Microsoft Certification
Compatible with Windows 7
Energy Class
Class D
71.5 Watt
Power Consumption (On mode)
63 W
Energy Consumption per Year
92 kWh
39.33 cm x 7.95 cm x 39.33 cm
5.8 kg
Energy Class
Class D
71.5 Watt
63 W
92 kWh
Diagonal Class
22"
Diagonal Size
21.6 in
Commercial Use
TV Tuner
No tuner
Video Interface
Composite, HDMI
PC Interface
HDCP Compatible
Dimensions
Without stand
39.33 cm
7.95 cm
39.33 cm
5.8 kg
Enclosure Colour
Display
Resolution
960 x 960
Image Aspect Ratio
1:1
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
10000:1
Brightness
450 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.1345 x 0.1345mm
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm, 300 x 300 mm
Audio System
Sound Output Mode
Stereo
Connector Type
VGA input , DVI-D input , DisplayPort , HDMI , Composite video input , Audio line-in , DVI-D output , Network , Serial
Power supply
Width (Shipping)
47.3 cm
Depth (Shipping)
18.7 cm
Height (Shipping)
47.3 cm
Weight (Shipping)
7 kg
Scroll to top
