BT.com
Wishlist
Samsung U32E850R 31.5" 3840x2160 4ms HDMI DisplayPort USB 3.0 LED Monitor
Delivery
Standard Due date unavailable
The UE850 UHD monitors offer rich picture contrast and rapid response time, creating a more life-like, non-distracting visual experience that simultaneously enhances performance. The UE850's improved resolution and dynamic connectivity drive efficiency for professional, creative and analytical tasks. Combined with ergonomic and environmentally-friendly advancements, these UE850 monitors deliver a complete, comfortable viewing experience.
What's in the box
  • Samsung UE850 Series U32E850R
  • HDMI cable
  • Mini DisplayPort-DisplayPort cable
  • SuperSpeed USB cable
Samsung UE850 Series U32E850R - LED monitor - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class B
Energy Consumption per Year
89 kWh
Power Consumption (On mode)
62 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch
0.1815 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Black, titan silver
74.03 cm x 27.86 cm x 49.35 cm
9.61 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, C-Tick, GOST, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, GB 17625.1, VCCI V-3, GB 9254-2008, TCO Displays 6.0, K60950-1, KCC KN22, KCC KN24, CNS 14336, CNS 13438, GB 4943-2011
Display Type
Energy Class
Class B
89 kWh
62 W
Diagonal Size
31.5"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1815 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, picture by picture, MagicRotation, game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, BFR/PVC-free, Image Size, PIP 2.0, USB Super-charging, Eye Saver Mode, 97% sRGB colour gamut
Black, titan silver
74.03 cm x 27.86 cm x 49.35 cm - with stand
9.61 kg
Headphones , 2 x HDMI , DisplayPort , 4 x USB 3.0
Mechanical
Tilt Angle
-5/+22
Swivel Angle
50
Rotation Angle
-1.5/+91.5
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
AC 120/230 V
Power Consumption Stand by
0.4 Watt
Power Consumption Sleep
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 74.03 cm - depth: 27.86 cm - height: 49.35 cm - weight: 9.61 kg , Without stand - width: 74.03 cm - depth: 6.77 cm - height: 43.98 cm - weight: 6.8 kg
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
Scroll to top
