BT.com
Wishlist
Samsung U32D970Q 32" 3840x2160 8ms DVI HDMI DisplayPort USB LED Monitor
Delivery
Standard Due date unavailable
Featuring a 32" UHD screen, this monitor provides nearly four times greater resolution than standard 1920 x 1080 FHD. View content with significantly greater precision and detail. So you can enjoy exceptional viewing clarity, be more productive and maximize efficiency.
Samsung UD970 Series U32D970Q - LED monitor - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class D
Energy Consumption per Year
131 kWh
Power Consumption (On mode)
90 W
USB 3.0 hub
Panel Type
Plane to Line Switching (PLS)
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz, DVI: 30 Hz)
Pixel Pitch
0.1816 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Matte black, titan silver
72.78 cm x 28 cm x 62 cm
13.7 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV GS, RoHS, EMI, TCO Displays, FOGRA
3 years warranty
Display Type
Energy Class
Class D
131 kWh
90 W
Diagonal Size
31.5"
Built-in Devices
USB 3.0 hub
Panel Type
Native Resolution
Pixel Pitch
0.1816 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Power off timer, MagicBright 3, game mode, Mega Dynamic Contrast Ratio, Eco Light Sensor, Eco Saving, Lifelike Color, Magic Upscale, Mercury free, Image Size, PIP 2.0, PBP, USB Super-charging, OSD Auto Rotate, AutoPivot sensor, programmable key
72.78 cm x 28 cm x 62 cm - with stand
13.7 kg
5 x USB 3.0 , HDMI , 2 x DisplayPort , DVI-D , Audio line-out
Mechanical
Tilt Angle
-5/+20
Swivel Angle
60
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm, 200 x 200 mm
1 x USB cable , 1 x DVI cable
Power Supply
Internal
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities, Samsung MultiScreen
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 72.78 cm - depth: 28 cm - height: 62 cm - weight: 13.7 kg , Without stand - width: 72.78 cm - depth: 6.21 cm - height: 42.73 cm - weight: 10.3 kg
ENERGY STAR Certified
Limited warranty - 36 months
Scroll to top
