BT.com
Wishlist
Samsung U28E570D 28" 3840x2160 1ms HDMI DP LED Monitor
Samsung U28E570D 28" 3840x2160 1ms...
£319.08
£319.08
Add to wishlist
Delivery
Standard Due date unavailable
Discover the detail of stunningly realistic UHD picture quality
The Samsung UE590 UHD monitor offers PC viewing, gaming and more, all in stunning Ultra HD picture quality. Superb images that boast a staggering 8 million pixels are delivered at a resolution 4x greater than Full HD. See your 4K content the way it was meant to be seen, with realistic detail that makes you feel like you’re really there. Experience a new level of clarity in Ultra High Definition.
Take your entertainment to new heights of immersion and comfort
  • AMD FreeSync: Dynamically syncs the screen refresh rate with the frame rate of your content to minimise input latency and dramatically reduce image tearing and stutter during gaming.
  • Upgraded HDMI Support: With an upgraded HDMI that supports UHD resolutions at a 60Hz refresh rate, 4K content plays smoothly without delay, even when connected to AV devices.
  • Game Mode: Instantly adjust your monitor settings for an optimised gaming experience through the on-screen display. Game Mode improves the darkness of the picture so that you can see all the action vividly.
  • Fast 1ms Response Time: See even the fastest on-screen motion clearly without any motion blur, judder or ghosting.
Experience unbeatable picture quality with razor sharp resolution and billions of colours
  • 1 Billion Colours: With 64 times more colours than conventional monitors, images are so detailed, accurate and natural that they will take your breath away.
  • Highest Brightness Level: With the highest brightness level of 370 cd/?, the picture quality is more vivid and brilliantly clear.
Powerful multitasking features for maximum productivity
  • PBP: Picture-by-Picture lets you view 2 different input sources on one screen while maintaining the picture quality of the original source.
  • PIP 2.0: Multitask while you watch a variety of content, thanks to support for even more inputs with Picture-in-Picture 2.0. Resize the second picture to cover up to 25% of the screen and position it anywhere you please, and even control the sound settings with ease.
Enhanced connectivity with a triple interface
  • The UE590 features a hardware interface with useful and advanced connections to maximize your gaming experience. It provides seamless connectivity with your PC and AV equipment with DisplayPort 1.2 and 2 different HDMI ports making it the perfect partner for your game console as well as your PC.
Sophisticated design in matte black & T-shaped stand with a metallic touch
  • Sophisticated Design: With thoughtful design and engineering, the UE590 is much more than a monitor with stunning looks—it’s carefully designed to keep the focus on your content viewing pleasure. It comes with a stunning matte black body framed perfectly by a narrow bezel with a metallic rim, elevated by a T-shaped stand with a matching metallic touch.
  • VESA Support: With support for VESA 75 X 75, you can easily mount it on any wall.
  • Tilt: Easily and smoothly tilt the screen forward 20° and backwards 2° for comfortable viewing.
Easy on the eyes for a more comfortable viewing experience
  • Eye Saver Mode: Unlike other colours emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye Saver Mode optimises your viewing comfort by smartly reducing blue light emissions at the touch of a button.
  • Flicker Free: Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
Samsung UE570 Series U28E570D - LED monitor - 4K - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
55 kWh
Power Consumption (On mode)
38 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.16 mm
Brightness
370 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms (grey-to-grey)
Colour Support
1 billion colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Black, metallic silver
66.09 cm x 18.71 cm x 46.85 cm
5.28 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
55 kWh
38 W
Diagonal Size
28"
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.16 mm
Brightness
370 cd/m²
Contrast Ratio
1000:1
Colour Support
1 billion colours
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Picture in picture, MagicBright, picture by picture, MagicAngle, game mode, Mega Infinity Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, 72% (NTSC 1976) colour gamut
66.09 cm x 18.71 cm x 46.85 cm - with stand
5.28 kg
Headphones , 2 x HDMI , DisplayPort
Mechanical
Tilt
Tilt Angle
-2/+20
Flat Panel Mount Interface
75 x 75 mm
PVC free
1 x DisplayPort cable
AC 120/230 V
Power Consumption (Off Mode)
0.3 Watt
Included Software
Easy Setting Box
Dimensions & Weight Details
With stand - width: 66.09 cm - depth: 18.71 cm - height: 46.85 cm - weight: 5.28 kg , Without stand - width: 66.09 cm - depth: 7.35 cm - height: 38.13 cm - weight: 4.71 kg
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
Scroll to top
