BT.com
Wishlist
Samsung TD55LDAH 55" IR Technology 10 Touch Large Format Display
Delivery
Standard Due date unavailable
Samsung Touch Overlay turns the display into an interactive board with dual drawing performance and allows for integrators and businesses to quickly add touch capabilities without the need to replace the display. The Touch Overlay seamlessly attaches to the frame of the bezel enabling a fully integrated touch display solution.
Samsung Touch Overlay CY-TD55LDAH - touch overlay
Touch overlay
Wired
127.61 cm x 2.68 cm x 76.49 cm
9.8 kg
Multi-Touch
Movement Detection Technology
Infrared
Antiglare surface, glass display overlay, handwriting recognition, aluminium body, anti-scratch surface, 10-point simultaneous touch
Samsung DB55D, DB55E, DH55D, DH55E, DM55D, DM55E
Touch overlay
127.61 cm
2.68 cm
76.49 cm
9.8 kg
Input Device
Wired
Infrared
Multi-Touch
Scroll to top
