Click to visit BT.com
BT.com
Wishlist
Samsung SyncMaster S24B300HL 23.6" LED Monitor - HDMI VGA
4.0*
Quicklinx: 8BKZWS00
Mfr#: LS24B300HL/EN
With the Samsung S24B300HL LED Monitor, you'll have a monitor that offers both more energy efficiency and viewing comfort. Magic Angle technology means you can enjoy comfortable viewing from wider range of angles, allowing you to watch TV sitting, standing, or even lying down. Your Samsung LED monitor also features Eco Saving for reduced bills and environmental impact. It adjusts brightness according to your needs, with three different energy-saving modes.
See it your way with wider viewing angles.
How do you like to watch movies? Do you like lying down on the couch? Sitting in your favourite chair? Cooking or exercising? Whether you're standing, sitting or lying down, Samsung Magic Angle makes sure that the movie always takes centre stage and that you're always comfortable. This means, thanks to the 5-mode angle management, that whatever angle you watch your Samsung monitor, you will enjoy a full visual experience with amazing picture clarity. So, start seeing your favourite movies and other multimedia in total comfort and without limitations thanks to Magic Angle.
Control brightness, conserve energy.
Eco saving makes saving energy easy. It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%, 25% and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung's commitment to saving energy is designed to help both you and the environment, and with up to 50% saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving
Samsung S24B300HL - LED monitor - 23.6"
LED-backlit LCD monitor - 23.6"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Black, high gloss
56.9 cm x 19.7 cm x 41.6 cm - with stand
3.8 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Display Type
Diagonal Size
23.6"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Power off timer, MagicTune, MagicColor, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio
Black, high gloss
3.8 kg
VGA , HDMI
Mechanical
Tilt
1 x VGA cable
Power Supply
External
AC 120/230 V ( 50/60 Hz )
30 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 56.9 cm - depth: 19.7 cm - height: 41.6 cm - weight: 3.8 kg , Without stand - width: 56.9 cm - depth: 5.3 cm - height: 34.2 cm - weight: 3.5 kg
EPEAT Compliant
EPEAT Gold
Customer reviews
Write a review for the Samsung SyncMaster S24B300HL 23.6" LED Monitor - HDMI VGA here!
Good value
Reviewed by Anonymous Review Posted 06/02/2013
Nice monitor for the price. Looks good, very light and slim, good brightness. My only criticisms are that the stand doesn't permit one to adjust the angle of the display, and it doesn't include a HDMI cable. Otherwise it would get 5*s.
  • Overall 4*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
