BT.com
Wishlist
Samsung SyncMaster S24A450BW - LCD display - TFT - LED backlight - 24" - widescreen - matte black
Delivery
Standard Due date unavailable
With a Samsung SA450 business monitor, you'll discover more comfortable viewing and greater energy-efficiency. Optimise your viewpoint by making adjustments to height, perspective and tilt that can benefit your posture as well as productivity. Moving and setting up your SA450 is easier too, with its lightweight and innovative design. Features like cable arrangement and the detachable adaptor also help you minimise clutter and maximise space. It's more energy efficient when in use and even allows you to reduce power consumption when it's not, thanks to the Adaptor On Off switch.
Samsung S24A450BW - LED monitor - 24"
LED-backlit LCD monitor - 24"
Aspect Ratio
Widescreen
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Height, pivot (rotation), tilt
Matte black
56 cm x 20.1 cm x 40 cm
6.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, ISO 9241-307, TCO '05
3 years warranty
Display Type
Diagonal Size
24"
Aspect Ratio
Widescreen
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
61 Hz
Horizontal Refresh Rate
75 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Power off timer, MagicColor, HDCP, MagicAngle, MagicBright 3
Matte black
56 cm x 20.1 cm x 40 cm - with stand
6.7 kg
VGA , DVI-D
Mechanical
Tilt Angle
25
Height Adjustment
100 mm
Wall mountable
Power Supply
External
29 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 56 cm - depth: 20.1 cm - height: 40 cm - weight: 6.7 kg , Without stand - width: 56 cm - depth: 5 cm - height: 37.4 cm - weight: 5.1 kg
ENERGY STAR Certified
Limited warranty - 3 years - pick-up and return
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Throw away your old small inefficient monitor and upgrade to this
Reviewed by Chris on 27/11/2011
The styling of this monitor appears to be targeted for monitor arrays i.e. narrow borders, sharp edges and practically invisible control buttons. The operation of the control buttons is, however, assisted by the menu display, which helpfully points out the location and function of each button.
There is no swivel adjustment and an annoying bright blinking LED on standby. I guess that may have been designed to encourage the user to turn off the monitor when not in use to eliminate standby power consumption, but standby power is almost zero anyway. Operational power is also low.
Samsung have provided a slot for the power supply at the top rear of the monitor. A neat idea, reducing desktop clutter. An on/off button is provided on the power supply to turn off that pesky blinking LED!
The picture quality is excellent - crisp and bright - I need to turn the brightness down to 35% to reduce eye strain!
Excellent value for money for a display with 1200 horizontal lines.
4* Solid Monitor but Pricey
Reviewed by Robert Davies on 09/06/2012
Decent picture quality & colours, great for web & work with text. Premium price for x1200, rather than 1080p.
Install was simple, but they include D-sub cable, NOT DVI which seems crazy (cheap?) in 2012 for a digital monitor.
The buttons for OSD display are black on black, hard to see without direct lighting, apart from that I found useability good.
By default screen has brightness at 100%, leading to saturated colours, it's bright and closer quality to old Pro CRT display, at brightness of 20%.. so turn it down for bettger colours!
Good product, for those want 1920x1200, the price premium on 1080p Monitors & lack of HDMI/Displayport connector & the crazy Analog cable provided make this monitor seem "conservative" & biz like. Samsung ought to refresh soon for connection options.
Scroll to top
