BT.com
Wishlist
Samsung SyncMaster S22A200B LED Backlit LCD 21.5" DVI, VGA, Tilt & Vesa Wall Mountable
Delivery
Standard Due date unavailable
The lightweight Samsung LED S22A200B Series 2 professional monitor is built to meet the challenges and demands of the modern workplace. Low power consumption helps you keep operating costs and environmental impact to a minimum. You can make the most of space and keep it tidy with innovative design features such as the detachable adaptor and adaptor neck stand. The useful carrying handle and easy wall-mounting also allow portability and streamlined installation.
Samsung SyncMaster S22A200B - LED monitor - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
Widescreen
Native Resolution
FullHD 1920 x 1080
Brightness
250 cd/m2
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Matte black
51.3 cm x 20.1 cm x 41 cm - with stand
3.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
DDC-2B, TCO Displays 5.0
Design
Flat 100mm x 100mm - Vesa Mountable
Display Type
Diagonal Size
21.5"
Aspect Ratio
Widescreen
Native Resolution
FullHD 1920 x 1080
Brightness
250 cd/m2
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Power off timer, MagicTune, MagicWizard, MagicColor, HDCP, MagicAngle, MagicBright 3, Mega Contrast
Matte black
3.6 kg
VGA , DVI-D
Mechanical
Tilt
Flat Panel Mount Interface
100 x 100 mm - Vesa Mountable
1 x VGA cable
Power Supply
External
22 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Dimensions & Weight Details
With stand - 51.3 cm x 20.1 cm x 41 cm x 3.6 g , Without stand - 51.3 cm x 5 cm x 31.7 cm
Scroll to top
