BT.com
Wishlist
Samsung SM460UX-2 46" 1920 x 1080 LCD Monitor
Delivery
Standard Due date unavailable
Imagine people responding to your message because they can see it. That's what happens with the Samsung UX series LCD public information displays. Advanced cooling technology and lower operating temperatures enable you to display your impressive images for a long time. With the Samsung UX series LCD displays, it's not hard to imagine.
This extra-thin, beautiful 46" LCD display has everything you need to get your message through to the most people. Plus, there's no need to worry about reliability. No matter where you place your display, images will be crystal-clear. The Samsung 460UX features industry-leading brightness, a brightness sensor that adjusts to ambient light, and a high dynamic contrast ratio that fine-tunes its intensity based on the picture.
Samsung 460UX-3 46" LCD flat panel display
250 Watt
Diagonal Class
46"
105 cm x 11.8 cm x 60.3 cm - without stand
24.5 kg
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
Image Aspect Ratio
16:9
TV Tuner
No tuner
On-screen menu, pivot, LightSensor Technology, picture by picture (no tuner), picture in picture (no tuner), progressive scan
Sound Output Mode
Stereo
Speaker System
2 speakers
Remote Control
Remote control
Microsoft Certification
Compatible with Windows 7
AC 120/230 V ( 50/60 Hz )
Environmental Standards
ENERGY STAR Qualified
250 Watt
Diagonal Class
46"
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Timer Functions
Sleep
Dimensions
Without stand
105 cm
11.8 cm
60.3 cm
24.5 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Dynamic Contrast Ratio
10000:1
Brightness
700 cd/m²
Colour Gamut
72%
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.53025 x 0.53025mm
Response Time
8 ms
Max V-Sync Rate
85 Hz
Max H-Sync Rate
81 kHz
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
1 x DVI-D input ( 24 PIN Digital DVI ) - rear , 1 x VGA / component video input ( 15 PIN HD D-Sub (HD-15) ) - rear , 1 x DVI-D output ( 24 PIN Digital DVI ) - rear , 1 x network ( RJ-45 ) - rear , 1 x composite video input ( RCA ) - rear , 2 x HDMI input ( 19 pin HDMI Type A ) - rear , 1 x audio line-in ( mini-phone stereo 3.5 mm ) - rear , 1 x audio line-in ( RCA x 2 ) - rear , 1 x audio line-out ( mini-phone stereo 3.5 mm ) - rear , 1 x DisplayPort ( 20 pin DisplayPort ) - rear , 2 x serial ( 9 PIN D-Sub ) - rear , 1 x USB - rear
VGA cable
ENERGY STAR Version
5.0
Power supply - internal
Nominal Voltage
Power Consumption Stand by / Sleep
2 Watt
Width (Shipping)
116 cm
Depth (Shipping)
32.5 cm
Height (Shipping)
73.3 cm
Weight (Shipping)
29.5 kg
Scroll to top
