BT.com
Wishlist
Samsung SM400DXN2 40" Display with Magic Info Software
Delivery
Standard Due date unavailable
When you're running a business, you need equipment that can handle the elements and won't let you down. That's why the longer lasting Samsung 400DXN-2 is perfect for all of your commercial needs. It will deliver amazing visual displays all day everyday. And for greater impact, it also comes with built-in speakers and picture in / by picture technology. Enjoy standing out with this perfect business tool.
Samsung SyncMaster 400DXn-2 40" LCD flat panel display
LCD flat panel display with built-in network media player
Diagonal Class
40"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
2 speakers
USB
4 ports
Remote Control
Standard remote
Microsoft Certification
Works with Windows Vista
290 Watt
93.2 cm x 13 cm x 54.8 cm
Environmental Standards
ENERGY STAR Qualified
290 Watt
Diagonal Class
40"
Combined with
Built-in network media player
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Timer Functions
Sleep
Dimensions
Without stand
93.2 cm
13 cm
54.8 cm
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
10000:1
Brightness
700 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.461 mm
Response Time
8 ms
Max V-Sync Rate
85 Hz
Max H-Sync Rate
81 kHz
Multiple Display Control (MDC)
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Ports Qty
4
Remote Control
Standard remote
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
DVI-HDCP , VGA input , Component video input , Component video output , Composite video input , HDMI , Network , 4 x USB , Serial
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
TUV GS, DDC-2B, ISO 13406-2, RoHS
ENERGY STAR Certified
Power supply - internal
Power Consumption Stand by / Sleep
5 Watt
Dimensions & Weight Details
Panel without stand - 93.2 cm x 13 cm x 54.8 cm , Panel with stand - 93.2 cm x 31.1 cm x 60.4 cm
Width (Shipping)
104 cm
Depth (Shipping)
31.1 cm
Height (Shipping)
66.7 cm
Weight (Shipping)
27.5 kg
Scroll to top
