Click to visit BT.com
BT.com
Wishlist
Samsung SM400DXN2 40" Display with Magic Info Software
Quicklinx: 70KSWS00
Mfr#: LH40BVTLBC/EN
When you're running a business, you need equipment that can handle the elements and won't let you down. That's why the longer lasting Samsung 400DXN-2 is perfect for all of your commercial needs. It will deliver amazing visual displays all day everyday. And for greater impact, it also comes with built-in speakers and picture in / by picture technology. Enjoy standing out with this perfect business tool.
Samsung SyncMaster 400DXn-2 40" LCD flat panel display
LCD flat panel display with built-in network media player
290 Watt
Diagonal Class
40"
93.2 cm x 13 cm x 54.8 cm - without stand
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
TV Tuner
No tuner
On-screen menu, DNIe Pro, Multiple Display Control (MDC), picture by picture (no tuner), picture in picture (no tuner), progressive scan
Sound Output Mode
Stereo
Speaker System
2 speakers
USB Port
4 ports
Remote Control
Remote control
Microsoft Certification
Works with Windows Vista
Environmental Standards
ENERGY STAR Qualified
290 Watt
Diagonal Class
40"
Combined with
Built-in network media player
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Timer Functions
Sleep
Dimensions
Without stand
93.2 cm
13 cm
54.8 cm
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
10000:1
Brightness
700 cd/m2
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.461 mm
Response Time
8 ms
Max V-Sync Rate
85 Hz
Max H-Sync Rate
81 kHz
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
4 ports
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
1 x DVI-HDCP ( 24 PIN Digital DVI ) , 1 x VGA input ( 15 PIN HD D-Sub (HD-15) ) , 1 x component video input ( BNC x 5 ) , 1 x component video output ( BNC x 5 ) , 1 x composite video input , 1 x HDMI ( 19 pin HDMI Type A ) , 1 x network ( RJ-45 ) , 4 x USB ( 4 PIN USB Type A ) , 1 x serial
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
TUV GS, DDC-2B, ISO 13406-2, RoHS
Power supply - internal
Power Consumption Stand by / Sleep
5 Watt
Dimensions & Weight Details
Panel without stand - 93.2 cm x 13 cm x 54.8 cm , Panel with stand - 93.2 cm x 31.1 cm x 60.4 cm
Width (Shipping)
104 cm
Depth (Shipping)
31.1 cm
Height (Shipping)
66.7 cm
Weight (Shipping)
27.5 kg
