Click to visit BT.com
BT.com
Wishlist
Samsung Series6 600B5BH I5-2520M 4GB 500GB W7Pro15.6" LED NVIDIA NVS4200M/Intel matte blk (dockable)
Quicklinx: 89MXWS00
Mfr#: NP600B5B-S03UK$$
When your business depends on it there's no point in taking chances. The Samsung series 6 notebook is the ultimate business notebook for superior usability, craftsmanship and performance. Its anti-reflective screen is brighter than normal displays, so you can use it for longer - even in sunlight - without your eyes getting tired. Intel vPro technology also makes it much easier to manage, as you can remotely monitor, diagnose and repair even an unresponsive notebook. And it's packed with advanced security tools, like fingerprint recognition, data encryption. So with the Samsung series 6 notebook you can simply do more, in more places, with much less hassle.
Model code
NP600B5B-S03UK
Operating System
Genuine Windows® 7 Professional (64-bit)
Intel® Core™ i5 Processor 2520M (2.50 GHz, 3 MB L3 Cache)
Main Chipset
Intel QM67 (Intel® vPro™)
Graphic Processor
NVIDIA® NVS™ 4200M Graphics, Optimus™ technology
Graphic Memory
1GB DDR3
LCD Display
15.6" SuperBright 300nit HD+ LED Display (1600 x 900), Anti-Reflective
System Memory
4GB DDR3 System Memory at 1333MHz (4GB x 1)
Memory Slot
2 DIMM Slots
Storage
HDD: 500GB S-ATA? Hard Drive (5400RPM), ODD: Super Multi Dual Layer
Multimedia
Sound: HD Audio, Sound Effect: Mic Noise Suppression - SoundAlive™, Speaker: 3 W Stereo Speaker (1.5 W x 2)
Integrated Camera
1.3 megapixel HD Webcam
Network
Wireless LAN: Intel 802.11abg/n (2x2), Wireless WAN: NO, Bluetooth v2.1
I/O Port
VGA: Yes, HDMI: Yes, Headphone Out, Mic In: Yes, Internal Mic available
USB:2 x USB 3.0 + 2 x USB 2.0 (Sleep-and-Charge), (eSATA + USB included)
Multi Card Slot: 7-in-1 (MS, MS Pro, SD, SDHC, MMC, MMC plus, xD)
Dock Port: Yes, DC-In (Power Port): Yes
In Put
Keyboard: 103/102 key, Touch Pad, Touch Screen: Touch Pad (Scroll Scope, Flat Type, Gesture UI)
Security
Lock: Kensington Lock Slot, Samsung Recovery Solution,TPM, FingerPrint Reader, Free Fall Sensor
S/W Security
BIOS Boot Up Password, HDD Password, Norton Internet Security(60-day Trial)*, Absolute Data Protection(90-day Trial)*
AC Adapter: 90 / 60 Watt, Standard Battery: 6 Cell (66Wh)
Physical Specification
Dimension (WxDxH): 370 x 248.3 x 28.6 ~ 35.3mm (14.5" x 9.7" x 1.12" ~ 1.38"), Weight: 2.6 Kg (5.73 lbs)
Software
Standard DVD: OS DVD*, Samsung Update Plus, Easy Display Manger, Easy Battery Manager, Easy Network Manager
Easy Partition Manager, Adobe Acrobat Reader, Samsung Support Center, Microsoft Office Starter 2010, Windows Live
