BT.com
Wishlist
Samsung Series 9 S27B970D 27" Quad HD LED 2560x1440 DVI HDMI USB Speakers-Metalic, black gloss
Free delivery
Delivery
Standard Due date unavailable
The slim profile and sleek design of the series 9 monitor boasts a sophisticated frame in front and a shimmering panel in back. The slim bezel and crystal-clear glass hidden-panel display create a stunning look, while the solid metal frame adds an elegant touch. Even when it's switched off, series 9 is sure to be the focal point of the room.
With a resolution of 2560 x 1440 the Wide Quad HD of the series 9 monitor gives you four times the resolution of 720p HDTV. It's the ideal solution for those who want the best picture quality.
See perfect colours from wherever you sit
Maximise your viewing experience with Samsung's superior PLS technology (Plane to Line Switching). Regular screens suffer from what is called Colour Shift, which reduces the picture quality and colour when viewed from an acute angle. The Samsung LED Monitor Series 9, which can cover an amazing 178° viewing angle both vertically and horizontally, boasts a crisp and detailed picture by maintaining true-to-life colour, even when viewed from extreme angels, so the experience is always vivid and brilliant.
See true colours with Photo Accuracy 100%
Nothing beats true-to-life clarity and colour. Samsung's Photo Accuracy 100% ensures that your captured moments, whether on digital camera or camcorder, are represented exactly as you remember them. The Photo Accuracy distinguished itself with its sRGB colour, which is the standard colour of digital devices such as monitors, digital cameras and scanner, and brings your captured moments to life without the annoying distortions. The Samsung LED Monitor Series 9 screen reproduces colour for crystal clear, realistic images and is the perfect way to relive precious memories.
See more content with unbelievable screen resolution
The Samsung LED Monitor Series 9 showcases an astounding WQHD display with 2560 x 1440 pixel resolution, which is four times the resolution of HD (720p). It is perfect for businesses and industries that rely on access to extremely fine monitor detail. The wide screen, which features dual link DVI and display port, allows for more detail to be viewed and is ideal for work places such as design and ad agencies and studios. The enhanced screen resolution provides greater efficiency and quality, and really is the must-have when delivering the best experience and high quality.
Enhance viewing from mobile to monitor
With Mobile High-Definition Link (MHL), experience entertainment with full-size monitor luxury and higher-quality HD viewing. MHL lets you watch video and other content on the move, then easily connect the mobile device to a monitor with the included cable. You can finish viewing in stunning HD anywhere you want, and charge devices while connected, too. Combine portability with home comfort for an optimised view.
The total audio-video solution with built-in speakers
With a built-in Samsung Stereo Speaker, a 5 Way Speaker delivers high-quality stereo sound and a richer multimedia experience. You'll enjoy enhanced movies and music, as if you were in a theatre or concert, thanks to Samsung's outstanding audio. Experience total convenience and make the most of home or office space with cost-efficient built-in speakers.
Samsung S27B970D - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
USB Hub
Aspect Ratio
Widescreen
Native Resolution
2560 x 1440
Pixel Pitch
0.229 mm
Brightness
285 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, DisplayPort
Speakers
Internal
Display Position Adjustments
Tilt
Metallic, black gloss
64.5 cm x 24.7 cm x 56.7 cm
7.9 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC-2B, TCO Displays 5.0, ISO 9241-307
2 years warranty
Display Type
Energy Class
Class B
Diagonal Size
27"
Built-in Devices
USB Hub
Aspect Ratio
Widescreen
Native Resolution
2560 x 1440
Pixel Pitch
0.229 mm
Brightness
285 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
24 - 60 Hz
Horizontal Refresh Rate
30 - 81 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Colour balance, gamma correction, uniformity
Power off timer, HDCP, Mega Dynamic Contrast Ratio, Mobile High-Definition Link (MHL), Eco Saving
64.5 cm x 24.7 cm x 56.7 cm - with stand
7.9 kg
Audio
Speakers - stereo - internal
DVI-D , HDMI , DisplayPort , 2 x USB 2.0
Mechanical
Tilt
Height Adjustment
100 mm
1 x DisplayPort cable , 1 x DVI cable , 1 x USB cable
Power Supply
External
53 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
Natural Color Expert
Dimensions & Weight Details
With stand - width: 64.5 cm - depth: 24.7 cm - height: 56.7 cm - weight: 7.9 kg , Without stand - width: 64.5 cm - depth: 2.92 m - height: 40.2 cm
Scroll to top
