BT.com
Wishlist
Samsung Series 4 S24C450BW 24" LED 1920x1200 VGA DVI Height Adjust DVI-D, VGA - matte black
Delivery
Standard Due date unavailable
With a host of features to enhance the user experience, such as the Height Adjustable Stand (HAS), this monitor offers a truly personalized experience. The advanced LED monitors also minimized running costs, which is also good for the environment. So, if you are serious about working, then this is the perfect choice.
Samsung S24C450BW - LED monitor - 24"
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Matte black
55.48 cm x 22.4 cm x 51.22 cm
5.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Display Type
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Power off timer, MagicTune, MagicRotation, MagicAngle, MagicBright 3, Eco Saving
Matte black
55.48 cm x 22.4 cm x 51.22 cm - with stand
5.1 kg
VGA , DVI-D
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
30 Watt
Power Consumption Stand by / Sleep
0.1 Watt
Dimensions & Weight Details
With stand - width: 55.48 cm - depth: 22.4 cm - height: 51.22 cm - weight: 5.1 kg , Without stand - width: 55.48 cm - depth: 5.42 cm - height: 35.93 cm - weight: 3.5 kg
Limited warranty - 3 years
10 °C
10 - 80%
Scroll to top
