BT.com
Wishlist
Samsung SE-506BB 6x Blu-Ray Writer Slim Portable USB 2.0 Black
Slim & Portable!
Delivery
Standard Due date unavailable
Huge capacity, vivid color, full HD and 3D contents. Enjoy all the advantages of Blu-ray with SE-506BB. Features a luxurious and anti-scratch surface, AV connectivity and is Windows 8 and Mac compatible.
It's smooth and elegantly-rounded casing with either black and white high-gloss finish simply demands attention
Watch old DVDs in HD and 3D - By entering the world of 3D, PowerDVD delivers Blu-ray 3D to any compatible 3D display and supports all 3D video files format. You can enjoy 3D from your DVD collection today.
Transform 2D movies into 3D
Convert regular DVD movies into a 3D experience with TruTheater™3D
BD&3D Advisor
CyberLink BD&3D Advisor tests to ensure that your PC is enabled to play Blu-ray Disc and Blu-ray 3D contents
Smart power technology
Just plug a single USB cable! - Smart Power Technology is a power management solution developed by Samsung, for the notebook that does not have enough USB ports (such as Ultrabook). With Smart Power Technology, you can use your external ODD by just plugging a single USB cable into your PC. You don't need to have an additional USB plug for gaining an extra power.
* Read/write speed may be decreased to its minimum speed when voltage is under 4.6V, and the power failure may be occurred when voltage is under 4.3V.
AV connectivity 2.0
Samsung Exclusive Technology! AV devices such as TVs are available for multimedia files on your disc by connecting Samsung Portable ODD via USB cable. Just hold down the eject button for 1.5 seconds with the tray open and the drive goes into AV connectivity mode.
Header / Manufacturer
Samsung
Header / Model
SE-506BB
Storage / Product Type
BDXL drive
Drive Type
BDXL Writer
Optical Storage / Type
BD-Writer
Enclosure Type
External
Disk drive
Header / Packaged Quantity
1
Optical Storage / CD / DVD Rewrite Speed
24x (CD) / 6x (DVD±RW) / 5x (DVD-RAM) / 2x (BD-RE) / 2x (BD-RE DL) / 2x (BD-RE TL)
Optical Storage / Read Speed
24x (CD) / 8x (DVD) / 6x (BD)
Optical Storage / Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL) / 6x (BD-R) / 6x (BD-R DL) / 4x (BD-R QL) / 4x (BD-R TL)
Optical Storage / Buffer Size
4 MB
Hi-Speed USB
Header / Compatibility
PC and Mac
Dimensions & Weight / Height
2 cm
Dimensions & Weight / Width
14.5 cm
Dimensions & Weight / Depth
14.5 cm
Dimensions & Weight / Weight
332 g
Resources
The following resources are available for the Samsung SE-506BB 6x Blu-Ray Writer Slim Portable USB 2.0 Black
Scroll to top
