BT.com
Wishlist
Samsung SE-218BB USB 2.0 UltraSlim (14mm) External DVD Writer
Delivery
Standard Due date unavailable
The SAMSUNG SE-218BB/RSBS is the world thinnest external DVD writer at mere 14mm in thickness and provides ultrabook-like looks with metallic hairline surface. Inside its fancy appearance, an array of technology, including Speed Adjustment Technology (S.A.T), Double O.P.C Technology, Tilt Actuator Compensation Technology (T.A.C) and Buffer Under Run Free technology work behind the scenes to ensure you always get the optimal recording quality. The AV connectivity supports Android tablet with USB port for CD Audio and Multimedia File play back, turning your digital device a mobile media center. 1-USB Port realized by smart power technology, eliminating the need for cumbersome adapter or power cord.
  • Ultra Thin & Light: World thinnest: 14mm (0.55 inch), 255g (0.56 lbs) Ultrabook Like: Metallic Hairline surfaces
  • Smart Power Technology: 1-USB Port realized by smart power technology
  • AV Connectivity 2.0: Supports Android tablets with USB ports ex.) Acer Iconia, Lenovo Thinkpad Tablet, Asus Transformer / (CD Audio, Multimedia File play back) / OS requirements: Honeycomb 3.1 or higher
  • Compatible with Windows as well as Mac: Windows XP or above, Mac OS X (10.4.6) or higher
Ultra Thin & Light
Measuring 14mm (0.55 inch) and weighing 255g (0.56 lbs), the SAMSUNG SE-218BB/RSBS is the world's thinnest external DVD driver, delivering a perfect match to your netbook and other digital devices.
Multi-Format Support
This DVD writer supports a broad range of recordable media format, including CD-R, CD-RW, DVD±R, DVD±RW, DVD±R dual layer and DVD RAM.
USB-powered for powerful on-the-go capability
Engineered to free you from power cords and AC adapters, you no longer need to be in your office to write DVDs. Thanks to its USB BUS power source you can write at maximum speed with no outlet in sight. So, don't let your hectic schedule slow you down, The Ultra Slim External DVD Writer was built to help you keep up.
Samsung SE-218BB - DVD±RW (±R DL) / DVD-RAM drive - USB 2.0 - external
DVD±RW (±R DL) / DVD-RAM drive - external
USB 2.0
14.8 cm x 14.3 cm x 1.4 cm
250 g
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Buffer Underrun Protection
Media Load Type
Tray
USB 2.0
14.8 cm
14.3 cm
1.4 cm
250 g
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Write Speed
Supported Media Formats
CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Mixed-mode CD, Photo CD, Video CD, CD-ROM, CD+G (Karaoke CD), DVD-Video
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Media Load Type
Tray
Access Time
150 ms (DVD), 150 ms (CD)
Buffer Size
1 MB
Tilt Actuator Compensation (TAC), Double Optimum Power Control, firmware upgradable
CD-Bridge, Video CD
1 x USB 2.0
RoHS
Package Type
Retail
Scroll to top
