Click to visit BT.com
BT.com
Wishlist
Samsung SE-208BW Optical SMART Hub Wireless External White
Quicklinx: 8HX7WS00
Mfr#: SE-208BW/UKWS
Drive Type: Other
Enclosure Type: External
Interface: USB
Colour: White
Type: Network drive
Standard delivery Delivered within 3-5 working days
13 in stock
£21.80
Link wirelessly from external storage devices to your tablets, smart phones, and smart TVs.
  • Your Favorite DVD Movies & Music CDs: Enjoy viewing your favorite DVDs and listening to your CDs on your tablets and smartphones wirelessly. the "mobile Smart Hub" application can be downloaded from the Appstore, Android Market, and Amazon.
  • Streaming Content Made Easy: Streaming content on your Samsung Optical SMART Hub has never been easier. With the Samsung Optical SMART Hub.
  • Enjoy AllShare: The AllShare application can be used on your Samsung Smart TV, tablets, and smartphones. The AllShare application allows you to enjoy wirelessly all your stored content from your Samsung Optical Smart Hub.
  • Access Your Files Wirelessly: Samsung Optical SMART Hub enables you to access your files wirelessly - wherever you are. No need to transfer files to your tablets and smartphones using your PC. Simple plug your USB storage into the Samsung Optical SMART Hub and instantly access files from your tablets and smartphones wirelessly.
  • Simple File Management: Easily manage your stored files from your tablets, smartphones,and PCs. Simply move, rename, copy, paste, or delete your files in any connected storage wirelessly. Your Samsung Optical SMART Hub acts as an additional network storage.
  • Always Be Connected: Samsung Optical SMART Hub allows your tablets and smartphones internet accessibility always - even while streaming data (music, movie, photos, etc.).
  • Connect 4 Devices Simultaneously: Your Samsung Optical SMART Hub supports 4 devices at a same time. Whether you are watching a movie DVD movie, listening to a CD, two devices can play two different tracks on the same discs simultaneously.
  • Windows 7 compatibility: The Samsung Slim External DVD Writer was engineered for ultra-compatibility, including Windows 7.
Samsung optical SmartHub SE-208BW - network drive
Network drive
Host Connectivity
USB 2.0 / Ethernet 10/100 / 802.11g
15 cm x 19.8 cm x 2.5 cm
430 g
Optical Storage
1 x DVD±RW (±R DL) / DVD-RAM - 24x (CD) / 8x (DVD±R) / 8x (DVD±R DL) (read) / 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL) / 5x (DVD-RAM) (write) / 24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) (rewrite)
Network adapter 10Mb LAN, 100Mb LAN, 802.11b, 802.11g
Network drive
Host Connectivity
15 cm
19.8 cm
2.5 cm
430 g
Enclosure Colour
White
Optical Storage
Read Speed
Write Speed
CD / DVD Rewrite Speed
Network adapter
Network / Transport Protocol
PPPoE, iSCSI, FTP, DHCP, CSMA/CD
Wireless Distribution System (WDS) support, firmware upgradable, Samba support, static IP mode
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
DLNA CERTIFIED
1 x USB 2.0 , 1 x Ethernet 100Base-TX - RJ-45
Samsung SE-208BW Optical SMART Hub Wireless External White Bundle deal on Samsung SE-208BW Optical SMART Hub Wireless External White
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£41.33
saving £8.26
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£31.79
saving £4.99
Drive Type: Other
Interface: USB
Colour: White
Type: Network drive
Brand: Samsung
Price Range Inc VAT: 0 - 50
