BT.com
Wishlist
Samsung S34E790C 34" 3440x1440 4ms HDMI DisplayPort Curved LED Monitor
Delivery
Standard Due date unavailable
With the innovations in technology, monitors have evolved to feature stunning curved screens that match the natural curvature of the human eye, providing a more uniform and comfortable viewing experience. With a best-in-class curvature and an ultra-wide 21:9 aspect ratio, the Samsung curved monitor SE790C delivers unrivaled comfort and truly immersive viewing.
The SE790C has what it takes to provide truly vibrant picture quality and comfortable enhanced viewing from any angle, optimized for your efficient working needs.
Manage all your windows on one ultra-wide panoramic display. Whether it's two windows side-by-side or a picture within a picture, boost your productivity with best-in-class multitasking features and outstanding picture quality.
Samsung SE790C Series S34E790C - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class C
Energy Consumption per Year
93 kWh
Power Consumption (On mode)
64 W
Curved Screen
USB 3.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
QHD 3440 x 1440 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Speakers
Internal
Display Position Adjustments
Height, tilt
High glossy black
82.15 cm x 27.55 cm x 45.2 cm
9.9 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class C
93 kWh
64 W
Diagonal Size
34"
Curved Screen
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, power off timer, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Flicker Free technology, Ultra-Flexible Height Adjustment System (HAS), side-by-side, Image Size, PIP 2.0, PBP
High glossy black
82.15 cm x 27.55 cm x 45.2 cm - with stand
9.9 kg
Audio
Speakers - stereo - internal
Output Power / Channel
7 Watt
DisplayPort , 2 x HDMI , Headphones , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Height, tilt
Tilt Angle
-2/+20
Height Adjustment
100 mm
Flat Panel Mount Interface
100 x 100 mm
Cleaning cloth
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable , 1 x Mini DisplayPort-DisplayPort adapter
Power Supply
External
77 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 82.15 cm - depth: 27.55 cm - height: 45.2 cm - weight: 9.9 kg , Without stand - width: 82.15 cm - depth: 5.15 cm - height: 36.4 cm - weight: 7.4 kg
ENERGY STAR Certified
Scroll to top
