BT.com
Wishlist
Samsung S32E590C 31.5" 1920x1080 4ms HDMI DisplayPort Curved LED Monitor
Delivery
Standard Due date unavailable
A natural fit for your eyes with a curvature of 3,000 R, delivering a wider field of view that's easy on the eyes for a more comfortable viewing experience. Experts have found that people perceive curves as more visually comforting than hard lines and angles. Simply viewing the curves of an object triggers relief in the brain.
More vivid than conventional monitors to provide truly brilliant pictures with deeper blacks, pristine whites, amazingly bright colors, and less light leakage.
More vivid and brilliantly clear with the highest brightness level of 350 cd/sq m enables you to see every intricate detail. Wide viewing angle: delivers a 178° wide viewing angle horizontally and vertically for optimal viewing experience from any angle.
With thoughtful design and engineering, the SE590C is much more than a monitor with stunning looks. Featuring a glossy black body that is framed perfectly by a narrow bezel and elevated by a T-shaped stand with a metallic touch, it's carefully designed to keep the focus on your content viewing pleasure.
Samsung SE590C Series S32E590C - LED monitor - curved - Full HD (1080p) - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
66 kWh
Power Consumption (On mode)
45 W
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.36375 mm
Brightness
350 cd/m²
Contrast Ratio
5000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Speakers
Internal
Display Position Adjustments
Tilt
72.91 cm x 21.43 cm x 52.39 cm
6.9 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
66 kWh
45 W
Diagonal Size
32"
Viewable Size
31.5"
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.36375 mm
Brightness
350 cd/m²
Contrast Ratio
5000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode
72.91 cm x 21.43 cm x 52.39 cm - with stand
6.9 kg
Audio
Speakers - stereo - internal
Output Power / Channel
5 Watt
DisplayPort , 2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
15
Flat Panel Mount Interface
200 x 200 mm
1 x HDMI cable
Power Supply
External
AC 120/230 V
34 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 72.91 cm - depth: 21.43 cm - height: 52.39 cm - weight: 6.9 kg , Without stand - width: 72.91 cm - depth: 9.06 cm - height: 42.51 cm - weight: 6 kg
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
Scroll to top
