BT.com
Wishlist
Samsung S27E650D 27" 1920x1080 4ms VGA DVI DisplayPort USB LED Monitor
Delivery
Standard Due date unavailable
Samsung's S27E650D Eco-Friendly LCD monitor delivers an unmatched user experience, while maximizing energy-savings and sustainable design for reduced environmental impact.
Using the monitor's ECO-Power Off mode - a first-of-its-kind - the S27E650D offers 0.00W power consumption when in off mode. This is significantly lower than the 0.3W to 0.5W experienced with the average monitor, leading to significant savings in energy, resource and cost over time.
Along with superior power consumption, the monitor is designed with a 30 percent recycled plastic and PVC-free body. The recycled plastic and PVC-free body offer health and environmental benefits throughout the monitor's lifecycle, beginning with production, where it reduces the emission of harmful pollutants. During use, the monitor keeps PVC-related toxins out of the user's home, school and office. Finally, when correctly disposed, the monitor prevents PVC from leaking into soil, crops and water supplies.
Designed to be dustproof and waterproof, the OHD Series displays' components are also IP56 certified for superior performance even under the toughest conditions.
Samsung SE650 Series S27E650D - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
USB Hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
63.9 cm x 22.4 cm x 40.28 cm
6.92 kg
Environmental Standards
ENERGY STAR Qualified
C-Tick, EN55022, SASO, EN55024, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, UL60950-1, GB 4943-2011, GB 17625.1-2012
3 years warranty
Display Type
Diagonal Size
27"
Built-in Devices
USB Hub
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus, 72% (NTSC 1976) colour gamut
63.9 cm x 22.4 cm x 40.28 cm - with stand
6.92 kg
VGA , DVI , DisplayPort , 2 x USB
Mechanical
Tilt Angle
-4/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
PVC free
1 x VGA cable , 1 x USB cable
AC 120/230 V
20 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.005 Watt
Windows 8.1
Dimensions & Weight Details
With stand - width: 63.9 cm - depth: 22.4 cm - height: 40.28 cm - weight: 6.92 kg , Without stand - width: 63.9 cm - depth: 5.76 cm - height: 37.81 cm - weight: 5.2 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
Scroll to top
