BT.com
Wishlist
Samsung S27E591C 27" 1920x1080 4ms VGA HDMI DisplayPort Curved LED Monitor
Delivery
Standard Due date unavailable
With thoughtful design and engineering, the SE591C is much more than a monitor with a stunning look. Featuring a glossy body that is framed perfectly by a narrow bezel and elevated by a T-shaped stand with a metallic touch, it’s carefully designed to keep the focus on your content viewing pleasure. Its optimal curvature ensures comfortable viewing, delivering a wider field of view that is pleasant for your eyes.
Samsung SE591C Series S27E591C - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34 W
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Speakers
Internal
Display Position Adjustments
Tilt
Glossy white
62.32 cm x 18.16 cm x 46.3 cm
5.65 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, ISO9241-307
2 years warranty
Display Type
Energy Class
Class B
50 kWh
34 W
Diagonal Size
27"
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, power off timer, HDCP, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Free technology, Mercury free, Image Size
Glossy white
62.32 cm x 18.16 cm x 46.3 cm - with stand
5.65 kg
Audio
Speakers - stereo - internal
Output Power / Channel
5 Watt
VGA , HDMI , DisplayPort , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-2/+20
Flat Panel Mount Interface
100 x 100 mm
1 x HDMI cable , 1 x audio cable
DDC-2B, ISO9241-307
Power Supply
External
24 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 62.32 cm - depth: 18.16 cm - height: 46.3 cm - weight: 5.65 kg , Without stand - width: 62.32 cm - depth: 5.99 cm - height: 36.57 cm - weight: 5.03 kg
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
Scroll to top
