BT.com
Wishlist
Samsung S27E510C 27" 1920 x 1080 4ms VGA HDMI Curved LED Monitor
Delivery
Standard Due date unavailable
With thoughtful design and engineering, the SE510C is much more than a monitor with stunning looks. Featuring a glossy black body that is framed perfectly by a narrow bezel and elevated by a T-shaped stand, it's carefully designed to keep the focus on your content viewing pleasure.
Samsung SE510C Series S27E510C - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
54 kWh
Power Consumption (On mode)
37 W
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
High glossy black
62.32 cm x 18.16 cm x 46.3 cm
5.52 kg
Display Type
Energy Class
Class B
54 kWh
37 W
Diagonal Size
27"
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Infinity Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, 72% (NTSC 1976) colour gamut
High glossy black
62.32 cm x 18.16 cm x 46.3 cm - with stand
5.52 kg
VGA , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-2/+20
Flat Panel Mount Interface
100 x 100 mm
T-shape stand
1 x VGA cable
AC 120/230 V
35 Watt
Power Consumption Sleep
0.3 Watt
Windows 8.1
Dimensions & Weight Details
With stand - width: 62.32 cm - depth: 18.16 cm - height: 46.3 cm - weight: 5.52 kg , Without stand - width: 62.32 cm - depth: 5.99 cm - height: 36.57 cm - weight: 4.91 kg
10 °C
10 - 80% (non-condensing)
Scroll to top
