BT.com
Wishlist
Samsung S27D590P 27" 1920x1080 5ms VGA HDMI LED Monitor
Delivery
Standard Due date unavailable
It takes a special kind of design to really make the most of your monitor's picture. Constructed from sophisticated metallic materials, the Samsung SD590 was created by the meeting of lines, with a clean and understated look that ensures nothing will distract you from the screen. Elevated by a sleek stand and neck, the picture almost seems to float weightlessly, framed perfectly by a super narrow bezel, and the monitor's clean back enhances its elegant silhouette.
Samsung SD590 Series S27D590P - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Panel Type
AD-PLS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
High glossy black
61.95 cm x 16.92 cm x 46.5 cm
4.96 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class A
44 kWh
30 W
Diagonal Size
27"
Panel Type
AD-PLS
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Power off timer, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Safe, Mercury free, Image Size
High glossy black
61.95 cm x 16.92 cm x 46.5 cm - with stand
4.96 kg
VGA , 2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-1/+15
1 x HDMI cable
Power Supply
External
33 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 61.95 cm - depth: 16.92 cm - height: 46.5 cm - weight: 4.96 kg , Without stand - width: 61.95 cm - depth: 5.85 cm - height: 38.86 cm - weight: 4.36 kg
ENERGY STAR Certified
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
£17.48
Scroll to top
