BT.com
Wishlist
Samsung S27D590C 27" 1920x1080 4ms VGA HDMI DisplayPort LED Curved Monitor
Delivery
Standard Due date unavailable
The SD590C boasts a curved screen that takes your entertainment experience to a whole new level. The radius and depth of the curve create a wider field of view and make the screen seem larger and more immersive than a flat screen of the same size. And because the screen edges are physically closer, matching the natural curves of your eyes, you get uniform viewing distance across the entire screen a more comfortable viewing experience that is easy on your eyes.
Samsung SD590C Series S27D590CS - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34 W
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
350 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Tilt
Glossy black
62.35 cm x 18.2 cm x 46.3 cm
5.6 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B
Display Type
Energy Class
Class B
50 kWh
34 W
Diagonal Size
27"
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, power off timer, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Safe, Mercury free, Image Size
Glossy black
62.35 cm x 18.2 cm x 46.3 cm - with stand
5.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
5 Watt
VGA , HDMI , DisplayPort , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-2/+20
Flat Panel Mount Interface
100 x 100 mm
1 x HDMI cable , 1 x audio cable
DDC-2B
Power Supply
External
35 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 62.35 cm - depth: 18.2 cm - height: 46.3 cm - weight: 5.6 kg , Without stand - width: 62.35 cm - depth: 5.95 cm - height: 36.6 cm - weight: 5 kg
ENERGY STAR Certified
Scroll to top
