BT.com
Wishlist
Samsung S24E450DL 24" 1920X1080 5ms VGA DVI DP TN LED Monitor
Delivery
Standard Due date unavailable
The SE450 Series provides an environmentally-friendly, user-friendly and budget-friendly yet high-quality desktop monitor solution for your business. The features of this 23.6" monitor include a simple and easy-to-use design, fully-adjustable stand, matte bezel with clearly-labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
What's in the box
  • Samsung SE450 Series S24E450DL
  • DisplayPort cable
  • DVI cable
Samsung SE450 Series S24E450DL - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
55.46 cm x 22.4 cm x 35.23 cm
5.48 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Diagonal Size
24"
Viewable Size
23.6"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus, 72% (NTSC 1976) colour gamut
55.46 cm x 22.4 cm x 35.23 cm - with stand
5.48 kg
VGA , DVI , DisplayPort , 2 x USB
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DisplayPort cable , 1 x DVI cable
AC 120/230 V
25 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.005 Watt
Dimensions & Weight Details
With stand - width: 55.46 cm - depth: 22.4 cm - height: 35.23 cm - weight: 5.48 kg , Without stand - width: 55.46 cm - depth: 5.54 cm - height: 33.05 cm - weight: 3.78 kg
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
Scroll to top
