BT.com
Wishlist
Samsung S24C650PL 23.6" LED PLS 1920x1080 VGA HDMI Display Port Hei
Delivery
Standard Due date unavailable
Designed specifically to enhance the user experience like no other monitor, it features the vivid 178° wide viewing angle for total convenience, a Height Adjustable Stand design, and handy pivot/swivel/tilt functionality. Combine these features with the recycled plastic parts and Eco certificates, and you have a monitor experience that not only high performing but also a lot greener.
Samsung S24C650PL - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class B
Energy Consumption per Year
49.6 kWh
Power Consumption (On mode)
34 W
USB 2.0 hub
Panel Type
AD-PLS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
55.46 cm x 22.4 cm x 35.73 cm
5.45 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Display Type
Energy Class
Class B
49.6 kWh
34 W
Diagonal Size
23.6"
Viewable Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
AD-PLS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Power off timer, MagicTune, MagicRotation, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
55.46 cm x 22.4 cm x 35.73 cm - with stand
5.45 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , HDMI , DisplayPort , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x USB cable , 1 x audio cable
Power Supply
Internal
35 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Samsung MultiScreen
Dimensions & Weight Details
With stand - width: 55.46 cm - depth: 22.4 cm - height: 35.73 cm - weight: 5.45 kg , Without stand - width: 55.46 cm - depth: 5.54 cm - height: 33.05 cm - weight: 3.75 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80%
Scroll to top
