Click to visit BT.com
BT.com
Wishlist
Samsung S24C650PL 23.6" LED PLS 1920x1080 VGA HDMI Display Port Hei
Quicklinx: 8ZBVWS00
Mfr#: LS24C65UPC/EN
Designed specifically to enhance the user experience like no other monitor, it features the vivid 178° wide viewing angle for total convenience, a Height Adjustable Stand design, and handy pivot/swivel/tilt functionality. Combine these features with the recycled plastic parts and Eco certificates, and you have a monitor experience that not only high performing but also a lot greener.
Samsung S24C650PL - LED monitor - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class B
Energy Consumption per Year
49.6 kWh
Power Consumption (On mode)
34 W
Built-in Devices
USB 2.0 hub
Panel Type
AD-PLS
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
55.46 cm x 22.4 cm x 35.73 cm - with stand
5.45 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Display Type
Energy Class
Class B
49.6 kWh
34 W
Diagonal Size
23.6"
Viewable Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
AD-PLS
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Power off timer, MagicTune, MagicRotation, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
5.45 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , HDMI , DisplayPort , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x USB cable , 1 x audio cable
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
35 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Samsung MultiScreen
Dimensions & Weight Details
With stand - width: 55.46 cm - depth: 22.4 cm - height: 35.73 cm - weight: 5.45 kg , Without stand - width: 55.46 cm - depth: 5.54 cm - height: 33.05 cm - weight: 3.75 kg
Limited warranty - 3 years
10 °C
10 - 80%
