Click to visit BT.com
BT.com
Wishlist
Samsung S24C200BL 23.6" 1920x1080 DVI-D VGA VESA WM & Tilt Black Monitor
Quicklinx: 8HF9WS00
Mfr#: LS24C20KBL/EN
Essential accessories
Maximized your viewing and your workspace. The Samsung Series 2 LED Business Monitor features a stylish narrow bezel to make the most of the screen and reduce distraction. Thanks to its compact space-saving design, you can also use your workspace better and keep it tidy. To help you reduce business costs, it's more energy-efficient too, consuming just 0.1 watts of electricity when in standby mode. You can even use the VESA Wall Mount to hang it securely and make the most of your space.
Samsung S24C200BL - LED monitor - 23.6"
LED-backlit LCD monitor - 23.6"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Matte black
55.46 cm x 18.5 cm x 41.23 cm - with stand
4.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Display Type
Diagonal Size
23.6"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Power off timer, MagicTune, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
Matte black
4.1 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-1/+20
Flat Panel Mount Interface
100 x 100 mm
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
30 Watt
Included Software
Samsung MultiScreen
Dimensions & Weight Details
With stand - width: 55.46 cm - depth: 18.5 cm - height: 41.23 cm - weight: 4.1 kg , Without stand - width: 55.46 cm - depth: 7.7 cm - height: 33.05 cm - weight: 3.75 kg
Limited warranty - 3 years
10 °C
10 - 80%
