BT.com
Wishlist
Samsung S23E650D 23" 1920x1080 4ms VGA DVI DisplayPort IPS LED Monitor
Delivery
Standard Due date unavailable
The Samsung LED Business Monitor SE650 has been designed to enhance work conditions and efficiency. Featuring Front Tactile Buttons, the SE650 minimizes costly errors found with high usage, which is a common problem with touch type button monitors. Furthermore, with its smarter design, users can still access these buttons when wall mounted, which can be an issue when monitors feature side panel buttons. Adding to the visual experience, the SE650 features a Narrow Matt Bezel. This reduces distraction around display area and delivers an experience that is immersive and engaging.
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SE650 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SE650 is ready to deliver an efficient and clean work space. The SE650 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimizing your office space is now easily achieved with the Samsung LED Business Monitor SE650.
The Samsung LED Business Monitor SE650 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer's body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce new ways of working. The SE650 Monitor can rotate 90 degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SE650.
Samsung SE650 Series S23E650D - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
USB Hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
54.29 cm x 22.4 cm x 34.97 cm
5.37 kg
Environmental Standards
ENERGY STAR Qualified
C-Tick, EN55022, SASO, EN55024, CISPR 22, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, UL60950-1, GB 4943-2011, GB 17625.1-2012
3 years warranty
Display Type
Diagonal Size
23"
Built-in Devices
USB Hub
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus, 72% (NTSC 1976) colour gamut
54.29 cm x 22.4 cm x 34.97 cm - with stand
5.37 kg
VGA , DVI , DisplayPort , 2 x USB 2.0
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x USB cable
AC 120/230 V
22 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.005 Watt
Dimensions & Weight Details
With stand - width: 54.29 cm - depth: 22.4 cm - height: 34.97 cm - weight: 5.37 kg , Without stand - width: 54.29 cm - depth: 5.53 cm - height: 32.14 cm - weight: 3.69 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
Accessories
StarTech.com Articulating Monitor Arm
Quicklinx: BHCN | In Stock
£122.23
StarTech.com Dual Monitor Stand
Quicklinx: C19Z | In Stock
£83.23
StarTech.com Cubicle Monitor Hanger
Quicklinx: CFQK | In Stock
£54.34
StarTech.com TV/Monitor Arm - Wallmount
Quicklinx: CFR4 | In Stock
£78.40
StarTech.com Monitor Arm - Heavy Duty
Quicklinx: CRY1 | In Stock
£87.34
Scroll to top
