BT.com
Wishlist
Samsung S23E450B 23" 1920x1080 5ms VGA DVI LED Monitor
Delivery
Standard Due date unavailable
The SE450 series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. Features include a simple and easy to use design, fully adjustable stand, matte bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
Samsung SE450 Series S23E450B - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2655 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
54.29 cm x 22.4 cm x 34.47 cm
5.13 kg
Environmental Standards
ENERGY STAR Qualified
C-Tick, EN55022, SASO, EN55024, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, GB 4943-2011, GB 17625.1-2012
3 years warranty
Display Type
Diagonal Size
23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2655 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus, 72% (NTSC 1976) colour gamut
54.29 cm x 22.4 cm x 34.47 cm - with stand
5.13 kg
VGA , DVI
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
PVC free
1 x VGA cable
AC 120/230 V
22 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.005 Watt
Windows 8.1
Dimensions & Weight Details
With stand - width: 54.29 cm - depth: 22.4 cm - height: 34.47 cm - weight: 5.13 kg , Without stand - width: 54.29 cm - depth: 5.53 cm - height: 32.14 cm - weight: 3.44 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
Scroll to top
